88 Chevy Check Engine Light On All The Time.
HotdogMB
also has fast idle and won't let me read the codes. Battery is fully charged and charging system is at 14.1 volts. Could this be a bad ground somewhere or something else?? I have changed the TPS as this is what it was last time. It only has 398,000klms on it so what could it be??LOL
Maybe the carb linkages need to be cleaned. That's one place to check if you haven't already
EFI, and cable is good with no tension.
Any help would be great.
Actually I meant the throttle body and the plates. I wonder if they might be carboned up and hanging up and not closing. Also check your idle air selenoid
I don't know how you are trying to read the codes?
If by the ALDL jumper method, it is possible this is not being done right.
Also it is possible the engine computer is toast.
Or wiring problem to ALDL connector. Bad terminal, etc.
Pretty much you would need to follow the troubleshooting instructions for testing the engine computer and ALDL test connector which would be in a GM Factory Service Manual set. (Order from helminc.com or a GM dealer.)
Also it is possible there is a problem with the wiring to the light itself (remote chance, but possible.) And the factory manual would list all situations where the light would stay on steady.
Also if you can, might want to take your vehicle to local auto parts store (Autozone?) and see if they can read your codes with their reader.
Hooked up the wires, the right way, as per the repair manual, and the light will not flash. It just stayes on all the time. I have changed the TPS and IAC with no good results. Seems like there is no power to the IAC because the plunger doesn't move with the key on. Is my ECU shot or what?? I by passed the fusable link in the power wire as well. Please help!! This is my hunting truck!!
How about telling us just what you did exactly to try and get the codes....w/o them it's going to hard to figure out what's going on....
I grounded the dignostic terminal, as per my repair manual, and turned the key on. No, flashes nothin. Light just stayes on. I have checked for codes in the past and it fashed codes then.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
