Mirror Disassembly
I have seen somewhere, I think in a post on here, where someone had posted pictures and how to on taking apart the mirror assembly for the gmt-900. I'm not just talking about removing it from the door, but actually completely taking it apart. Does anyone know where I can find this info. I have done a search and have not come up with anything. Thanks
To pop the glass off you adjust the glass so it is in towards the truck and up, then you put your fingers under the glass at the bottom outter side and pull firmly but gently. The glass will pop right off.
Once in there, you need a Torx bit and simple tools like a screw driver.
