Heated Mirror Replacement
Anyone know where i should get replacement heated mirror glass from and how much $ it should cost? My mirrors are ok but the heated part isnt and id like to fix before winter. Last winter neither mirror was heating up which sucks when plowing and i checked the connections and theres no corrosion so im assuming its the glass itself where my rear def does work.
Do you have turn signals integrated into your mirrors, or no?
Also, just because the connections aren't corroded doesn't mean there might not be a different issue. Have you verified that there isn't a blown fuse somewhere?
All fuses are good and i dont have signals in the mirror. I havent checked for voltage yet because ill prob break the glass when removing so i wanted to have replacements just in case.
  • 5 years later...
i also have a broken passenger mirror (just the glass) on my 2013. I looked around for replacment glass which seems easy to get but numerous (muth) links on "how to" replacement do not open. Does anyone have any suggestions or new links on how to replace just the glass?
