Door Hinge Replacement Gmt900
Haven't looked up a part number yet but wanted to see if anyone has had a problem with their front hinges? Both doors squeek but the passsengers side is very loud. The source of the noise is the hinge roller not spinning when i close the door. Now mind you i maintain this truck fairly well so why would the hinge roller freeze up? I have tried almost every type of rust spray with no luck.
Cant seem to find a part number on the hinges. Looked on several sites and i get the feeling its a dealer only part. Anyone know how i can get a part number???
Call the parts dept. at the dealer.
Have you completely removed it to try cleaning/soaking it?
Hit it with some sort of penetrating oil, that should loosen the roller up.
Oops, read everything but the last sentence, disregard what I said.
Could this be a warranty issue? If nothing is working to quiet the squeek, then I'd at least talk to the dealer before I bought new hinges on a fairly new truck.
I was under the impression that the warranty was up on my truck. Its an 07 with 54,000 miles on it. Hmmm...maybe i should call them and ask.
Your body-parts warranty expired at 36,000 miles.
Just got a price from the dealer of $ 58.10 for a hinge. Could have been worse i guess.
The part number if anyone else needs it is # 25958197
This is for a GMT900 pass. side upper front dooor hinge
  • 3 months later...
I have the exact same problem on my driver side. The roller is seized and I cannot it free...
Truck is out of warranty and the dealer wants $180 to install new hinge (60 for the hinge, 30 for paint, 90 for labor).
I need to look into how hard it is to change myself...
Part number for the driver side is: 25958196
