How Much Oil For F & R Differential
I have a 2500hd 4wd and I was going to order some Swepco 212 gear lube for the F &R differential. I looked at the manual and it does not say how much only to the fill level and to use a 75w-90 synth lubricant. Any approx ideas?
Also What other type lubricants are reccommended? or best to sticlk w/ GM brand?
Thanks
Steve
You need to know what rear end you have, including ring gear size.
Looking at all the options based on the information you've provided, looks like you would need at least 5 qts total for both ends. 2 front, 3 rear.
One place you can look for capacities is at the Amsoil site. Look for Product Lookup Guide.
Hope this helps.
2004 CHEVROLET TRUCK
CAPACITIES
Engine, with filter..........6.0 quarts[1]
Cooling System, W/ FR & RR AC Initial Fill..........16.0 quarts
Cooling System, W/ Front AC Initial Fill..........14.0 quarts
Automatic Transmission, 4L60-E Initial Fill..........5.0 quarts
Automatic Transmission, Total Fill
4 speed 4L60-E..........11.0 quarts
Differential, with 8.25 ring gear Front..........3.0 pints
Differential, with 9.25 ring gear Front..........3.2 pints
Differential, with 10.50 ring gear Rear..........5.5 pints
Differential, with 11.50 ring gear Rear..........7.6 pints
Differential, with 8.60 ring gear Rear..........4.2 pints
Differential, with 9.50 ring gear Rear..........5.5 pints
Transfer Case,NP8..........4.0 pints
Transfer Case,NR3/NR4..........3.0 pints
Transfer Case,NVG 246-NP8..........4.0 pints
Transfer Case,NVG 261-NP2..........4.0 pints
Transfer Case,NVG 263-NP1..........4.0 pints
Thanks, all I know is it has 4:10 gears. Looking for an approximate amount to purchase from the rep, so I will not come up shy when servicing.
It comes in gallon containers , so I would guess 2 would be fine.
Thanks for the help
Steve
