Defrost And Clunking Noise
sansonekm
I've got two separate problems I just haven't been able to look around and try to find the answer since it's been raining the past 7 days straight...
First problem is that when I change my controls to defrost everything still blows out of the front vents and not the defrost vents. I plan on rebooting my computer once I get a chance to see if that fixes the problem.
Second problem is after I'm driving and I get to a stop light once I've been in an idle for about 20-30 second I'll hear/feel a clunk noise below me sorta in front of where the seat sits. It makes the noise once and then it won't make it again till a start and stop again.
I'm just looking for some possible ideas on what to look for once this never ending rain lets up.
99 GMC Sierra 2500 2WD
Can't help much on your noise issue (sounds drivetrain related though...imho), but the problem with the vents may be a faulty HVAC Vacuume Actuator. It's a door that controls where the air flow is directed. I had the same problem in my '01 Silverado last year. And it seems to be a pretty common occurance. Definitely a DIY job...
I'd check the slip yoke/spline joint. Make sure its lubed so it is able to move freely
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
