Horrible Service With Dealership
I have a 2007 new body style Silverado Ext cab. I purchased it in Dec 2007. Since then I've had the drivers side A-pillar replaced 3 times due to warpage, and the truck in for the squeaking rear doors 3 times. Their answer is tape. The tape looks tacky, collected dirt, and didn't fix the issue. The third time my truck was in for the doors my box of bungees I use to tie down cargo in the bed ended up missing. I've always taken my truck in for service to this dealership with this truck. I logged a complaint 3 weeks ago regarding the 4th A-pillar this truck has seen as it's also warped, and for the rear doors that are STILL squeaking whenever I hit a bump or are on a rough patch of road.
A lady from customer service called me back and promised me she would take care of these issues and said she would call me back. Over a week later she never called, so I called back and was told she was supposed to have a meeting with the service manager the following morning and promised me a callback right after. No callback happened.
I just called and asked for the GM and/or owner of the dealership as I am writing a letter to have my complaint in writing. I was told someone would call me back. To my surprise 20 min later someone did, the customer service manager. He wants me to bring my truck in a week from tomorrow and he will personally look at it. What sucked though is he is only offering a $40 shop credit for my missing bungees. No apologies or anything.
I was told that the A-pillar warpage is a known issue with the GMT-900 and GM doesn't know what to do to fix it.
It's a truck. What do you expect? It's gonna make noises. If you want something quiet and "solid" buy a car. Trucks just make noises. Good luck, and I hope things work out for ya though..... :P
Did know about this....Are you talking about the A pillar like THE A pillar the windshield goes against?
If your talking about the pillar by the windshield. My 07 was straight when I traded in June with 32k mi and my 09 is straight too. My extended cab doors creak in the morning while turning or going over bumps, but goes away once I move a bit. I'm going to grease the weather strip someday to end that.
Mike
Yes, the A-pillar molding that goes up against the windshield. To me they should look symmetrical on both driver and passenger. Passenger side looks fine, it's the drivers side that is warped.
None of our company trucks are having this A pillar problem.
I have not heard of this problem before myself, but I hope you ge it resolved soon. As far as customer service goes I agree that concept is gone for the most part. Stinks about your bungees but you know what they say about stealerships :thumbs: of course they will not admit its possible one of there employes took them.
So as stated above, its the A Pillar molding, not the A pillar itself that you have had replaced? several times? Do you have a bug shield on the front of your truck?
Are you talking about the inside windshield pillar trim? The one on the right side on my truck was warped when I bought the truck. It was replaced under warranty, but it is only marginally better. It has to do with insufficient number of clips used to install a rather long piece of trim, plus inconsistent (=crappy) workmanship, such as off center windshield installation.
It's a truck. What do you expect? It's gonna make noises. If you want something quiet and "solid" buy a car. Trucks just make noises. Good luck, and I hope things work out for ya though..... :(
Thats getting old and lame, just because its a truck please....... :thumbs:
I know it's a truck, but it should still be solidly built too. My stepdad's Tundra doesn't have this issue....
:thumbs: This is the first time I've ever heard of this, and I know quite a few people who own/drive GMT900s....
Maybe not, but the Tundra's have a crap load of other problems. We even have a few on this board who have switched back to GM from Crapota.
Well, took the truck in to have the customer service manager look at it. He had it for about an hour and said the A-pillar cover is a defect and it has to do with the way the windshield is installed. There's no fix for it. As far as the rear doors squeaking on the ext cab, his solution is to spray some silicone sealant on the weatherstripping once a month. He gave me a $50 shop credit for the missing box of bungees that they stole.
I hate this truck now. I tried to trade it in at the SAME dealership for a Traverse but they would only give me $16k for it. They don't even value their own vehicles very well.
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
