Awd On 2008 Silverado Z71
tylusk
Will running my truck in AWD on dry pavement for a large number of miles damage my transmission or transfer case? Basically I bought the truck last year and when I picked it up at the dealership it was in AWD. I've driven it for about 15000 miles and never changed the setting on the selector switch except when I've been offroad. Also I just had it in for its scheduled maintenance, but nothing was said concerning the transfer case. With that said, is there still the possibility of prematurely burning out the clutch package or differential if I continue to run it in AWD? Any advice would be greatly appreciated. Thanks
you mean Auto-4wd, not AWD right? theres a huge difference.
while i would not advise leaving a selectable transfer case in 'auto' mode on dry pavement, if you dont have any problems now you're likely ok. put it in 2WD and change out the fluid for good measure
I apologize, yes I meant to say Auto 4wd. But being as this is my first 4x4 with an automatic transfer case, would you mind explaining the difference between the AWD and the Auto 4wd? My truck before this was a 2004 Tacoma which unfortunately died on the side of a gravel road with the cab and frame beyond repair so I am not very familiar with GM products. Thanks for the advice Matt and I will go ahead and get the fluid changed.
No problem. AWD is designed to work on dry pavement, 4WD is not. Basically AWD is like having a differential in the middle of the truck and will allow the front and rear driveshafts to spin at different speeds (which is required when you're turning. 4WD transfer cases lock the front and rear driveshafts together with a clutch system and thus cause parts to bind when going around a turn.
At least for the system that was in the GMT800 trucks, when in Auto-4WD mode you're in 4WD when starting from a stop. After a certain speed (maybe 10mph.. cant remember?) the truck goes into 2WD and will engage 4WD if any wheel slippage is sensed.
In my 2005 I would instantly know I was in Auto-4WD if I was in a parking lot making a turn. I also used to have customers bring their trucks to the shop and complain that "something doesnt feel right when turning"... the common solution was that they left Auto-4WD on.
Edit: lol just to clarrify... GMT800 means 1999 through 2007 body styles. GMT900 is the 2007.5 and new trucks.
Thanks for the clarification Matt. I'm not sure about the GMT800 series but on my 900 the only thing I noticed while engaged in Auto4wd was that the steering response seemed to be highly sensitive or at least greater than what you would expect from a full sized truck. I never experienced any binding or reduced turn radius like you would normally get while in 4H or 4L. Once again thanks for the info and have a good one.
You sure about that? I have had Auto 4wd since 1999 and I have never noticed any binding on dry pavement while turning with Autotrac engaged. I am pretty sure it is always in 2wd until slippage is sensed.
Yea im pretty sure about that. I looked into it and read a tech doc about the system that explained the binding. Also, its not as noticeable on all vehicles: i remember a statement along the lines of "Some vehicles may exhibit binding etc etc. This is normal for the system." however, there were a few iterations of the controls so im not sure if this was a feature for 03+, i dont remember the date range effected
Well, find that tech doc then. Cuz until I see it, I am calling :lol:
I'll bet an e-beer ( :thumbs: ) that it's always in 2wd until slippage is detected.
what are you basing your opinion on? that your truck never experienced binding? i forgot, your truck is representative of every truck built by gm....
i cant find that tech doc online and i no longer have access to Mitchell. maybe rob or someone that has access and can do some searching for it.
i guess your truck never experienced loss of power steering either, which was also deemed 'normal' by gm and i do have the tsb for that...... .but maybe that tsb is wrong because jeffs truck never experienced it.
No, I am basing it on how I understand AutoTrac to function. Feel free to prove me wrong, but until then, I am calling BS.
But thanks for being a dickhead! :thumbs:
in lamens terms, the truck is in 2wd until it senses slipping. a few years ago people were complaining about binding when in auto mode. gm released a tech doc that said to imrpove system performance some torque is applied to the front until the vehicle starts moving and that this binding is normal for the system. they even said it will not result in damage but i dont believe that aspect of it.
i guess im a dickhead because i dont have a copy of this report and im basing my posts on diagnostic work that i performed as a tech, not just on "well i had a truck once that...."
not going to argue with you about, readers can choose what they want to believe... theres another thread where someone said they notice slight binding when in auto mode, i guess their truck is broken or something
WTF is a "Lamen"? :lol:
I never once said my opinion was based on my truck. I simply stated I have never experienced binding while in auto 4wd. My understanding of Autotrac is based on what I have read about how Autotrac works and I never once claimed it as absolute fact. I simply said until you provide some FACTS, I am sticking with my belief.
Now, kindly go **** yourself. :thumbs:
Edit: Oh and BTW, earlier you said "when in Auto-4WD mode you're in 4WD when starting from a stop" and above you said "some torque is applied to the front..." Which is it?
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
