New To The Forums
BigP5792
Hey, I'm new to the forums here. This last spring I was lucky enough to find a 1994 GMC Sierra SLE 5.7l with only 53,000 miles (57,000 now). I bought it and have done some very minor upgrades like an aftermarket cd deck, a Thrush glasspack, bed liner, and I'm ordering my new cb radio and dual 4' whips this week :( .
Things I would like to do soon are rhino lining the bed rails, drop in K&N filter and eventually a back rack. Hopefully this forum can help me with some of that.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
