Need Thes Parts Gone.
factory tail lights from 01 2500hd good condition. have holes drilled for strobe lights, all wiring and junction block that mounts under bed. $80
01 2500hd heater control switch works fine does not have rear defrost $30
01 2500hd standard chrome mirrors power only. $70 possibly 2 sets available
nova electronics strobe tube power supply 90W 6 bulb output. $70
cant find pics on computer right now, have to just take new ones.
its the model 906 nova electronics.
its out put is 90W @ 6 bulbs and 60W @ 4 bulbs. yes i have both the power and component control wires. both are about 5' long give or take.
So then the only things I would need to buy would be the actual strobes themselves? How did the wires work if they were only 5 feet long? Can I just splice into them and make them longer to run say to the tail lights?
No,No,No,No,........ The wires in including are the wires for 12V supply power, and battery ground. And the wiring connector for the switch or switches to control the flash parrerns. these strobes can be controlled by three switches, one regular on off and two momentary switches. Or you can control them from six different switches, but dont worry i have the wiring diagram for this ill send along too.
I am not including the 3 wire for the strobe lights themselves, you can get it on ebay all the time.
Here is an example of how the multiple switches work:
SWITCH 1: Powers strobe in Right Front Headlight
SWITCH 2: Powers strobe in Left Front Headlight
SWITCH 3: Powers strobe in Right Rear Taillight
SWITCH 4: Powers strobe in Left Rear Taillight
SWITCH 5: (momentary) Controls flash pattern
SWITCH 6: (momentary) Controls hi/lo (intensity)
This is the three switch set up:
SWITCH 1: Powers all four strobe lights
SWITCH2: (momentary) Controls flash pattern
SWITCH3: (momentary) Controls hi/lo (intensity)
Yea I figured that out after i typed that. So the only things I need are the strobe wires and strobe tubes rated to at least 90 watts? I'll get some momentary switches from radio shack and just use the wiring for the roof beacon that came with the plow package for the on/off switch. I'm trying to decide if it would be more worth it to just buy an entire kit. By the time I'm done piecing all this together it's almost the same price anyway.
    • We've been fans of the 40-20-40 front seat in the lower trims; specifically the leather option on the "3-across" version of the  40-20-40. I hope this can still be ordered in the "Silverado" or RST trim packages.  AND .... if dual exhausts are a part of the Custom trim,  does that mean a V8 package is available on Customs ?  Has the RST trim been discontinued ?  When ordering a V8 on one of these lower trims .... must it be the 5.7 ?  Or, on 4WD units can the 6.6 be ordered ?
    • I like it.   In a world of vehicle front ends that look like they've had a little too much nipping and tucking, I appreciate that GM went with a bold and professional look for the new Silverado and kept the aggression understated. The new 1500 looks a little more like the current 2500.   The interior looks well done as usual, although I'm not a fan of billboard screens on the dash. At least recess the gauge cluster screen. I see passenger screens as "keeping up with the Joneses'" in automotive interiors of late, which is fine. I don't think they belong in most pickups, but choice is good. Maybe some day I'll appreciate having one. Probably not, but, maybe.   Yet another steering wheel and airbag design. I wonder what it costs to have so many different models of airbags and buttons and steering wheel frames. IMO, pick a good one and stick with it. The new one is very...luxurious...looking. Again, not bad, but also not what I'd expect in a pickup.   GM has left us awaiting engine choice announcements and official details.     What will I be ordering on day one?   Nothing. I like my 2025 and it would be silly to get rid of it just to have a 2027.
    • I'm also waiting to see if they confirm Apple CarPlay, because I'm not interested in subscription fees just to use the hardware I already purchased.    In closeups it looks like it gets the Colorado/Canyon center screen based headlight controls which I despise. They also appear to lose all the hard switches for functions like seat heating and cooling, parking sensors, lane control, traction control, etc. which means they're all screen/menu based, so verdict is out on how well those will work with gloves or wet/dirty hands.  Admittedly they don't show the left knee area of the dash, but I don't see hard switches for locker control on the ZR2, and the "mode" switch appears to eliminate the rotary dial with a quick way to access tow/haul.  My 2021 has had multiple screen failures and at times the screen just locks up, goes black, or reboots while driving even after replacement, so loosing the ability to access many of these functions, especially lighting control would be pretty frustrating.   There aren't enough photos or detailed trim details other than one mention of "available microfiber trim" to confirm, but the use of microfiber on the seats and or center console is a deal killer for me.  Just because you drive a ZR2 or High Country, doesn't mean you don't work out of it, and that material is difficult at best to keep clean and looking decent.   Lexus and several other brands are using it on seats, dash, and door panels now, I assume as a cost and weight saving measure,  and it looks horrible 1-2 years into ownership.  I see what appears to be piano black on the doors and center console in some photos, which also has no place in ANY vehicle in my opinion because it mars and scratches too easily, especially for a truck.  Will be interesting to see what GMC comes out with when the Sierra is released as far as materials go.
    • Im a fan.  Simply moving the screen up helps the look of the interior.  I feel like GM dropped the ball on the current gen having the screen not at the same level as the top of the gauge cluster.  The GMCs look better with the vents above the screen to close that gap.
    • I hear you, its just not something one would even think of that the new oil in the container isn't filtered to a spec one would expect it to be.    As to a passenger vehicle theme and the maintenance requirement to meet to ensure a warranty is honored, these days with claims of life time transmission fluid on some models and the limited amount of oil changes that would bring one to the end of the factory warranty, that sells vehicles for those that like to hear "easy care maintenance free", but the manufacturer certainly knows different as to what that more than likely means for the longevity of some of the components if given that minimum spec maintenance. Then again I imagine there are a fair number of people that really don't care as long the vehicle gets them a certain number of years down the road because they are the type that want the next new thing, new and improved ... more bells and crap etc on the new one on the show room floor. Manufacturers have learned the phycological game to entice the customer out of their money !
