Egr Valve
You may or may not have an EGR depending on what emissions system is on your truck. Thats dictated by state emissions. You should be able to see it when the engine cover is removed. If you have DBW you do not have one.
Can anyone tell me where the EGR valve is located on a 2003 silverado 1500 with the 5.3L? Thanks
My 05 is Drive By Wire and I do not have one. Now that I think about it 03 and up probably don't have one.
Agent orange is kicking in today.......
