Your Best Friend
dlstewart01
Most people say they marry their best friend. I call BS. Lock your wife and your dog in your trunk for an hour. When you open it, who's the one happy to see you.
148 times in a row it was my dog.
YOU ARE AN A$$ HOLE!!!!!!!!!!!
WHY WOULD YOU LOCK YOUR DOG IN THE TRUCK?????
Its TRUNK not Truck, and its just a JOKE...............
WHY WOULD YOU LOCK YOUR DOG IN THE TRUNK?????
Fixed
Really...A Joke.....thanks Tips. :thumbs::D
I hate to say it, but I think my wife would figure it out walking to the truck before the dog. Unless I told we were going shopping! :thumbs:
Why would I put my wife and dog in my trunk? That's were I put the dead hookers.
Sucks to be you than.
Its an option....dealer installed.
_Nomad_ has it cause of all the hooker killin'
I mean no cop would look in a truck for a trunk...that's how he gets away with it.
Oh shit...I hope there's no PO PO readin this site man...I just blew your secret.
    President Roberto
    President Roberto
  • Who's Online   4 Members, 0 Anonymous, 1,042 Guests (See full list)
