'03 Quadrasteer Shocks, Aftermarket Available?
I have 2 quadrasteers, and love them. #1- 03 Denalli Pickup, #2 -03 Yukon, Ride needs help as years go by, had it in to shop, and was told only shocks available were GM, and they were ove $300+ eack. I loved my quadrasteers till now. I understand there is a sensor witha plug in the shock. Anybody know of a aftermarket, that I can love my trucks again.
Thanks
I don't know of any "specifically" for the Quadrasteer trucks,As you know the Q-Steer trucks are equipped with the ride control suspension,hence the sensor in the shocks,and the switch on the dash that firm-up the ride when activated.
You could probably get a set of Bilsteins for them,Thats what I would try.
I'm sure someone on here has been in your shoes before and will post their solution.
Heres the description of the ride control system....
Service Information
2003 GMC Truck GMC Sierra Denali | Sierra, Silverado (VIN C/K) Service Manual | Document ID: 663485
Selectable Ride Description and Operation:
The selectable ride (SR) suspension system allows the driver to choose between 2 distinct damping levels, firm and normal.
The SR dampers are gas charged units which provide damping by forcing hydraulic fluid through internal orifices within each shock in order to resist suspension movement. Each shock contains an internal solenoid actuator that the SR switch controls. This solenoid actuator controls the size of the orifice that the hydraulic fluid is forced through, thus altering the ride characteristics of the vehicle.
Voltage is supplied to the switch via the ignition 1 voltage circuit from the SEO IGN Fuse. When the system is on, the voltage is supplied to terminal A of each shock providing firmer damping. Ground is supplied to terminal B of each shock.
  • 1 year later...
I have a 2002 Chevy Silverado with the ride control switch. I have replaced the switch multiple times. Cost is about $60 at the dealer. I recently stopped getting new ones and fixed the switch myself. I was able to replace the push-button switch with a black rocker switch and it works fine. Looks stock and will not fail as the O&M switch did. If you are interested let me know. The fix cost about $25 and should not fail as the original one did. Send me a message if interested.
- John
Thanks
Since jduca brought this back from the dead, I figured I might as well ask what shocks you ended up buying for your trucks...? Thanks!
    • Sounds like converting will be a bigger endeavor than I was thinking. This truck doesn't have 2Hi like the Suburban did. The Tahoe has 4Hi and 4Lo and a button to turn of traction control.   From what I understand the Stabilitrak uses open diff in the front and rear. When wheel speed is not the same the stabilitrak uses the ABS system to slowdown the spinning wheel(s) to transfer power to the slower non-spinning wheel(s). I thought the transfer case was open too. Being able to transfer power either more to front or rear depending on wheel spin. Maybe I miss understood some information with you saying and power transfer is 50-50. Thanks
    • My brother has a 2007 Avalanche with afm 5.3. It`s got 176,000 miles. Runs like a clock. Never been apart. Co worker has a 2010 Tahoe with afm 5.3. 230,000 miles. Never been apart. Runs like a clock. So, even though cyl deac is a weak spot, they can go the distance.   BUT, these engines had the oil changed regularly, AND had 5w30 as spec. I wonder if they would have lasted this far on 0w20? I`ll bet not.
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
    • get a good code reader, and find out what problems the truck has noticed by reading codes. cheap ones can only get basic engine codes, you may want to get one that can get codes from all the computers in your truck.
    • This is sort of my point, salvage yards aren't overflowing with all these 'poorly' maintained trucks - excellent/good/servicable condition otherwise, salvaged only as a result of a bad engine from poor oil change regiment.    In my area, there are no 2007 to newer gm trucks/suvs in any salvage yards. A few are in the 'recyclers' with very obvious reasons for being there - wrecked.
