No Parking Lights Or Turn Signals
I have an 07 silverado classic. last week i go to get in my truck and when i unlocked it noticed that the lights dont flash like usuall, i start it up and try my blinkers and nothing happens, i also have no tail lights. could this be the bcm causing these problems or something else.
Will
You say tail lights....do you mean Brake lights as well??
I am thinking Multifunction switch...or park light relay
Try your Brake lights and hazard lights and see if they work
the tail lights dont work.
brake lights and hazards do work
I have checked all underhood fuses and they are good to.
Did you try the odd ball fuses? I had the running lights go out and it was a fuse for the BCM (if i remember correctly). the fuse was in the dirverside panel.
I pulled every fuse both on the driverside panel and underhood and they all look good. could the bcm itself be bad?
