Side To Side Play In Steering Rack?
illMATTic
Service has had my truck for close to a week now. I took it in because I heard some noise in the steering and had some side to side play. When i move the steering wheel back and forth, you can see the steering rack move side to side in conjunction with the noise I hear.
They told me there is supposed to be play in it. Is this true? I can see a good 1/4" movement right where is bolts to the frame on the driver side.
thanks, Matt
.... welll, I have heard of some '07s that have worn out ball joints already!!!!!
.... particularly on trucks with lift or lowering kits
.... normal....? who knows what is normal, but it is happening!
.... if it is at the dealership, then there is a perfect chance to compare the 'normal play' in the steering to an equivalent truck with 0 miles on it from their inventory
... my bet is you need new ball joints (if that is what it is, it should about 10 minutes to diagnose, and two years to fight for the warranty replacement)
... the noise could come from shocks or shock mount bushings as well.... but again, pretty easy to diagnose
There should be NO side to side play between the crossmember and the steering rack.
Good idea posted above, have the idiot that's telling you it's normal walk outside and show you it do the same on a brand new truck.
FYI, if they are persistent that it IS normal, then tell them to put it in writing and sign off on it..... and mention the words safety hazard & liability and see what they say :shakehead:
Ok service has blamed everything on the lowering kit ofcoarse. They didnt even look at the steering rack. As soon as they put it up on the lift and looked at it, they immediatly blame the lowering kit. Damn it!
I was acctually under the truck with the tech and pointed out the spot where I saw the movement.
He said "oh yeah they are supposed to have some movement. The rack is mounted with rubber bushings". WTF????
So now the service mannager tells me that what ever his tech tells him he has to go with. I said a few choice words and then asked him if all the trucks on the lot have this play. The manager replied with his shoulders in the air, "well if my tech says so".
No work was performed at all. What do I do now?
Matt
Matt, the steering racks are mounted with rubber bushings... but they shouldn't have 1/4" of play!! Actually, with the truck in the air there should be 0" of play because there's no force on them... imagine how much your rack must move when you're taking a corner when all that force is transferred through the rack&pinion.
At this point, its you Vs them which SUCKS because you won't get good service and then even if you make them put another truck on a lift and the steering rack has no play, it sounds like they'll still try to blame it on the lowering kit.... so its all about how much you're willing to argue.
Me personally, id go up the chain in command.
If you didn't already demand that they put another truck on a lift and show you the play in a brand new vehicle, you may want to just try finding a different dealer. you gotta be able to put your foot down man :shakehead:
I am going to try to talk to the service manager tomorrow. He was not around today when I was there. :shakehead:
No pics of the kit yet. Its only been on for two weeks now. It is just a set 2" spindles and 2" strut up front. Its the same style kit that 1000's of people have used for years now.
thanks guys, Ill let you know what I come up with tomorrow.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
