Carpet Replacement In A 2000 Yukon Xl?
I am seriously considering replacing the carpet in my 2000 Yukon XL. It is close to beyond steaming or shampooing.
I'm in New Orleans and have been quoted no less than $900 for full carpet replacement (front and back). I can buy the pre-molded carpet and all of the material myself for around $300 so I am thinking of tackling the job on my own.
Has anyone done this? What all is involved? Are there instructions on taking out any of the side panels? The console? I figure the seat removal is fairly straight forward but the all of the side panels?? I dunno!
I would appreciate any and all help!
Zack
I think the seat removal will be the hardest part of it all. Most of the side panels can be easily removed, and I'm sure there are guides online making it even easier to remove the panels (explaining where screws, clips, etc. may be, so you can easily pry up on the trim).
Save the money and do the work yourself...
DO IT!
Pulling the seats and seat belts isn't a huge deal. You'll need to remove the sill trim and some of the quarter panel and center post trim. It's best if you have at least two people for the task but it's not that hard... especially considering the money saved. You should take pics and do a HOW TO thread here!
Thought about doing it to the 04 Escalade, carpet is reallllyy bad. Looked into it and it doesnt seem to hard. Just gotta un-bolt the seats, and most of the panels are [push pins or clips] so just lightly pull on the panels and they should snap off. I think the 00 yukons are the same interiors pretty much??
(Pictures don't show up when copying and pasting from the service manual)
Carpet Replacement - Front Utility
Removal Procedure
Remove the front seats. Refer to Seat Replacement - Front Bucket in Seats.
Remove the floor center console. Refer to Console Replacement in Instrument Panel, Gauges and Console.
Remove the lower bracket from the I/P to the floor to allow carpet removal.
Remove the center seat. Refer to Seat Replacement - Center in Seats.
Remove the floor mats.
Remove the transfer case shifter bezel, if equipped.
Remove the side sill trim plates. Refer to Door Sill Plate Replacement .
Remove the side kick panels both side. Refer to Trim Panel Replacement - Hinge Pillar .
Remove the garnish molding center pillar trim. Refer to Garnish Molding Replacement - Center Pillar .
Remove the carpet.
Installation Procedure
Caution
In order to avoid personal injury or vehicle damage when you repair or replace the carpet, use the same thickness and material size as the original installation. Always return the carpet to the original location.
Install the carpet.
Install the garnish molding center pillar trim. Refer to Garnish Molding Replacement - Center Pillar .
Install the side kick panels. Refer to Trim Panel Replacement - Hinge Pillar .
Install the side sill trim plates. Refer to Door Sill Plate Replacement .
Install the transfer case shifter bezel, if equipped.
Install the floor mats.
Install the center seats. Refer to Seat Replacement - Center in Seats.
Install the lower bracket from the I/P to the floor.
Install the floor center console. Refer to Console Replacement in Instrument Panel, Gauges and Console.
Install the front seats. Refer to Seat Replacement - Front Bucket in Seats.
Carpet Replacement - Rear
Removal Procedure
Remove the rear seat. Refer to Seat Replacement - Rear in Seats.
Remove the second rear seat if equipped. Refer to Seat Replacement - Rear in Seats.
Remove the rear door sill trim plates. Refer to Door Sill Plate Replacement .
Remove the endgate or the liftgate door sill trim plate. Refer to Door Sill Plate Replacement - Lift Gate .
Remove the trim panels for the rear quarter. Refer to Trim Panel Replacement - Rear Quarter .
Remove the bolts that retain the cargo tie down hooks to the floor.
Remove the cargo tie down hooks.
Remove the rear carpet from the vehicle.
Caution
Install the rear carpet to the vehicle.
Install the cargo tie down hooks.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the bolts that retain the cargo tie down hooks to the floor. Tighten
Tighten the bolts to 35 N·m (26 lb ft).
Install the endgate or the liftgate door sill trim plate. Refer to Door Sill Plate Replacement - Lift Gate .
Install the trim panels for the rear quarter. Refer to Trim Panel Replacement - Rear Quarter .
Install the door sill trim plates. Refer to Door Sill Plate Replacement .
Install the second rear seat if equipped. Refer to Seat Replacement - Rear in Seats.
Install the rear seat. Refer to Seat Replacement - Rear in Seats.
Removal Procedure
Remove the floor center console. Refer to Console Replacement in Instrument Panel, Gauges and Console. .
Remove the carpet.
Caution
Install the carpet.
Removal Procedure
Caution
Notice
NOTE: HAVE THE DEALER PULL THE PICTURES UP AND PRINT THEM FOR YOU. ( center console, seats, side pannels,ect.)
