How dogs are better than women
NewbieZ71
HOW DOGS ARE BETTER THAN WOMEN:
Dogs don't cry.
Dogs love it when your friends come over.
Dogs don't care if you use their shampoo.
Dogs think you sing great.
A dog's time in the bathroom is confined to a quick drink.
Dogs don't expect you to call when you are running late.
The later you are, the more excited dogs are to see you.
Dogs will forgive you for playing with other dogs.
Dogs don't notice if you call them by another dog's name.
Dogs are excited by rough play.
Dogs don't mind if you give their offspring away.
Dogs understand that farts are funny.
Dogs love red meat.
Dogs can appreciate excessive body hair.
Anyone can get a good-looking dog.
If a dog is gorgeous, other dogs don't hate it.
Dogs don't shop.
Dogs like it when you leave lots of things on the floor.
A dog's disposition stays the same all month long.
Dogs never need to examine the relationship.
A dog's parents never visit.
Dogs love long car trips.
Dogs understand that instincts are better than asking for directions.
Actually, now that I think about it...you guys deserve ALL you get if its dished out by a female GTMC member.....I'm talking ALL you get...........every bit...! :sigh:
 :0 real funny.....not.  :D
Funny....that's what I say about all these women bashing jokes...
I see the men can dish it out but can't take it back........ :sigh:
You see, I am just going to keep my mouth shut...cause I dang well know that no matter what any of us guys say, we will lose and Sarah will put all us guys in our place without breaking a sweat.
I am with Newbie on this one, Go Sarah, she has us on this one.  Yes dogs may be better, but there are a few things that make women a whole lot better, which she pointed out.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
