Disable Auto Headlights 2010 Tahoe
izack98
I have had the auto-headlamps disabled in my 2010 Tahoe. Installed a resistor in the place of the ambient light sensor on the dash to fool the vehicle into thinking it is daytime all the time (simplistic explanation I know) Now, that it is done, at night when I turn on the headlights, the dash lightest come on their highest setting. I am unable to dime the dash lights. When I turn the dial to dim the dash lights nothing happens - they stay at their brightest.
Anyone have a work around for this?
I know that even when the auto headlights are not disabled this way, during the day when the headlights are off the dash lights come on their highest setting and you cannot adjust them. So I guess its a normal function when the truck thinks its daylight. I'd still like to see if anyone has overcome this.
I always scratch my head :thumbs: as to why you would want to disable the auto headlights.
But that said you could expand your circuit to include a relay such that when the lights are off your resistor is in place, when on the orignal sensor is in place or it is open.
The dash light, at least in the newer vehicles, is controlled by a pulse width modulator, so you can drive the LEDs properly, you're not supposed to just drop voltage to them.
There are two different dimming circuits in the truck. One is for all the LEDs (symbols in the gauge cluster, displays) which uses a PWM signal and the ones you can dim by the dimming switch are still incandecent.
If you can live with the brighter LEDs you can tap into the incandesent circuit and adjust the voltage.
Which ones are incadecent? The knob between the fog and dome light override dims all of my lights. The FSM shows a dimmer that goes right into the BCM which would be the variable resistor that controls the rate of charge/discharge on a capacitor which triggers the timer chip. Or maybe it's a little different in the BCM but it doesn't directly control the power to any lights.
The FSM shows at least 3 PWM outputs from the BCM, all listed under LED and I/P Bulb Dimming but I don't see any other types of dimming components.
Most of the switches have incadecent lights it looks like, but they are still on a PWM circuit, so you still have the same problem, can't adjust them when you have the AHLs disabled.
I wouldn't mind disabling these things, but this problem isn't going to sit well with me, so I'm going to wire in some variable resistors (a bunch in series) that are in parallel with the ambient light sensor to find what works well for me and then probably take that stuff out and wire in some fixed resistors. That way I can get the lights to turn on and off when I feel they should be on. I'm tired of driving around at 10 am or 4 pm with the freaking lights on. I know the light bulb people love DRLs and AHLs the way they are setup.
Now that I think about it I can't conclusively state that the bulbs I saw were incadecent. When I took apart the 4wd switch for my indicator light adapter development it looked like an incadecent bulb but it may have been a special LED. I also measured varying voltages at its input when I changed the dimming knob but the PWM signal is at 100Hz so my volt meter could have been able to accuratly calculate an average voltage. I didn't look at that circuit with a scope since it wasn't relevant to my product.
I think the best aproach would be to leave it auto, like someone said, but add in parrallel resistors to lower the sensitivity.
If you were set on having a switch then using a relay would be best to change between resistor and light sensor. If you don't use the dome override button you could probably use that as your headlight switch.
Or just leave it and live with the lights coming on early, I don't see the harm, they aren't that bright. My bulbs have lasted 70k miles with the AHL
Just a heads up, if you disable your DRL your likely violating local or State laws. Not a big deal maybe but if your involved in an accident, and your vehicle is inspected, your liability increases.
Are there any associated warranty issues?
I always scratch my head :lol: as to why you would want to disable the auto headlights.
Some guys don't want their HIDs flashing on and off too frequently as the bulbs warm up slower than halogen. Others run SilverStar upgrades that don't have a very long bulb life.
Hmmm. I wonder why that would be the case, when most vehicles don't even have DRLs to begin with.
No more so than driving around with burned out DRL bulbs, lol.
  • 9 months later...
How would you use a relay to switch between resistor and light sensor?
    • First off use it in the way you’re more comfortable. In working in off road situations most of my life I used 4WD low range very little. In most cases when equipped I used auto 4WD. If I wanted maximum control going up and down very steep terrain  I used low range. Especially if I was driving a diesel. Same with very rutted terrain. In very muddy or snowy conditions I wanted momentum so high range worked well for that. With gravel ramps with limited traction I would try high range first. I would want smooth even increasing speed if I was fighting traction. Low range could give you too much to the wheels breaking traction trying to move.
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
