Wheel Flares
well I order Bushwacker pocket flares, should I leave them black or paint them. The rear wheels wells are getting painted black. Just wondering your thoughts.
BLACK!!!
And get some 3M undercoating, tape and spray those Rear wheel wells and your set! Nice Truck!
I would just put them on to test fit them and see if you like them black. If not take the off and get them painted.
I think it will look good either way.
I think white would look good, but also black too. :uhoh: Tough call. If it were mine I would go white.
I'm with this guy! Can't go wrong with this method.
Painted for sure. They will take away from your truck way too much with black. A friend had fender flares(black) on his F350 and it looked alright, just had them painted and WOW! what a difference! Just make sure the painter sands the grain down(if rough finish), if its smooth, make sure they get scuffed. Post pics!
BLACK!!!
+1
