Love My G-80
Gentlemen,
I know the g-80 can be fragile but mine has 150,000 miles on it and works great.
We are having some horrible weather in Prescott today and my truck got stuck in a parking lot. I gently allowed the wheels to spin and felt the diff lock up. Instantly I pulled out and it was very impressive.
Ken
Gentlemen,
Ken
That is great, the one in my 03 quit working at around 15,000 miles the one in my 08 is still working at 45,000 and the one in my 09 has 12,000 with no issues.
my father in laws went on his 08 WT at 99,895 miles. He told the dealer that it wouldnt move and that it was making a horrible noise comming out of the rearend. Towed it in......sooooo the shop tech hears that it would not move, drop and trear into the transmission and end up replacing some seals. None real big but all the clutches looked good. Went into the transfer case, looked good. SO he stops in to see what they had found and they have trans and transfer cases tore down. He said, i told you it was comming from the rear end and both of the techs turned and looked at the rearend and there was a BIG hole in the top of the diff cover where it decided to push half of the ring gear out the top......Thanks for the once over, glad the rest of the drive train is good 110 miles from the end of the 100k warranty.....and the complete rear end!
He drives it pretty hard .....100K in 2 years
but yes, the G80 works pretty darn good.
My G80 is starting to act up at 19000 miles...
if on tarmac it won't lock up unless i do a standstill burnout... i can drive in circles with the one wheel spinning all i want unless i start spinning wheels from a standstill...
Quickest way is to look at RPO codes in glove box. Look for G80
or do a burnout.. both wheels means it's got a locker... one wheel is a open diff...
I love mine. I did a swap for an open rear end and put in a G80 from an older K1500. It really is nice to have. If I ever have a 2WD truck, I'm definitely putting one in.
Here's a YouTube video of what happens if you have a G80 and are doing a burnout. Pay close attention to the far (passenger) tire. You see it spinning before the drivers tire and you also here the "click" of it engaging.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
