My 6.2 taps really bad on a cold start in the morning. I have to let it warm up a few mins before driving and it goes away. Really bothers me as to what the heck it could be. It's like this all year not just cold weather.
Edited by michigan2500hd
Flexplate. That's what I'm calling. Start your truck up and then get out of it and crawl underneath it and try to find the source of the sound. If it seems to come right from the bell housing on the tranny, you probably have a bad flexplate. Mine cracked in like 8 places and sounded terrible.
Would the noise go away once the engine is warmed up? I notice mine has what I thought was a little valve train noise when idling in park but I could just be "over listening" to it. Do the 2011 silverados with the 6.2 have a history of bad flex plates?
GM uses a crappy stamped steel plate for their flexplates and they can break. It's not super common but also not super rare. Typically a cracked plate is loudest when the engine is running unloaded meaning in park or neutral. When you shift into gear or start to accelerate you put a load on the plate and that force is enough to push it together enough to keep it quiet but the minute you coast and let rpm drop the noise comes back. If it is a flexplate, fix it! Don't let it go. Yes it is possible to put several thousand miles on a broken one but it's a disaster waiting to happen. If it totally let's go and grenades itself, there is a big metal disc heading right into the cab and it will slice through the truck like butter.
Edited by servantsalesmen
It is not the flex plate. You are describing something entirely different. When the truck is in neutral or park, there is not tapping. You can rev the engine in park or neutral and there is no tapping. However, once it is in gear there is tapping at low rpms around 20mph-30mph when you lightly "feather" the gas pedal.
The GMC dealer told me that it has something to do with my front differential but I am hesitant to let those guys have their way with my truck without knowing for sure what it is.
  • 1 month later...
My 09 Denali is making the same knock. Sounds like the growl from the predator when driven cold. I can shift into neutral at speed or parked at idle and rev the engine with no knock. Once the tranny hits 120 degrees and the motor is at 205-210 the knock goes away. I've heard piston slap and lifter tick before, slap and tick generally go away in 30-60secs unless extreme cold temps. My knock is there are long as the trans and motor are under 120/210. Is this a tranny issue? pump or converter???
Best way to describe the knock when accelerating is this.
http://youtu.be/OQwA14YWdqA
Has anyone had this fixed?
Hi KWIKNVA,
We're sorry to hear that you are also experiencing this clicking noise in your vehicle. We can certainly understand how frustrating this must be. Unfortunately, we're unable to provide technical advice, but we'd like to look into this for you. Feel free to send us a private message in reference to this thread if further assistance is needed. We look forward to hearing from you!
Kristen A.
GM Customer Care
Can anyone confirm that they have the same noise that is in Z06killers video ? also found at this link
It is exactly what I have. Almost sounds driveline related, possible axle or front drive shaft being that it is AWD. It does NOT make the sound during rev only under driving acceleration.
I do hate the sound but more interested in making sure it isnt something major that can go out on me while driving.
That "Rattle" noise in the video by Z06killers sounds to me like the rattle described as the flexplate rattle ( sounds like heat shield rattle) which is common. Hard to be certain as it also sounds like he is driving on a gravel road with the windows down. Clearly to me it isn't a "knock". I'm like kwoodwo. He has almost described my symptoms. My issue is what would cause a knock that actually goes away once the tranny hits 120-130 degrees and the engine is at 200-210?? However, the knock I hear is at 1000-1800 rpms. I can bring the truck to 30-40mph and shift into neutral and rev the motor and no knock at cold temps. I can idle on a cold start in park and no knock. Once in gear and I accelerate the knock is there until the temps come up which takes about 5-10mins. Not piston slap which would go away on avg. 5-60 secs after start up. I listen to a video with a 6.2L with piston slap and it sounded like someone banging a aluminum bat against the block. My knock sound just like the growl of the predator.
I've consulted two of my local tranny shops that have been in the business for 25 & 80 plus years and these symptoms didn't jump out at them as something they had seen before. The flexplate rattle is something they said they see often with the 6L80 trannys. So, I'm running out of ideas. Every logical idea seems viable until you throw the fact that the noise goes away when the motor isn't under a load or is at normal running temps. So, if it ain't Flexplate "rattle", "Piston slap", or "lifter tap" I have no SEL, no visible or audible exhaust leaks, no misfires or poor performance. Because the truck runs so good I don't see the need to pay crazy labor cost to have the motor or trans torn down. If I can pin point the the problem then I may throw cash at it.
kwoodwo! What was the end result?
I have a 2007 Yukon Denali with 187K miles and have the same noise as the you tube video. Usually occurs at 1800 rpm around 70-75 mph. I have taken to dealer for test drive so they could hear it twice and it did not create the sound. both times it was a rainy day. Anyone notice this either their issue? Reading these posts definitely seems like a systemic issue. hope somebody has figured it out.
  • 2 months later...
Hi there I have the same problem but I know what it is. Its a cracked exhaust manifold or leak. Take off your heat shild have a friend plug the muffler and listen for any air or fum leaks. I got this info from a Chevy dealer and that's how I found the problem I am going to try to fix it tomorrow with a high temp liquid metal compound. I hope this was helpful and Ill post back with the results of the fix later.
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
