Accumulator/refigerant Question
I believe that the cycling switch has quit on my Silverado. It doesn't blow cold and the system isn't cycling. It is not accepting a charge, either. From everything that I have read, it appears that the cycling switch has gone bad. I can get one for like $25, but I need clarification on a couple of things:
1) Is it true that this part just screws into the accumulator?
2) Do I have to evacuate the refigerant first? I don't know if unscrewing the part opens the system up or not.
Thanks.
Mine has a schraeder valve, valve core, that prevents refrigeration loss. Even if yours does not, as long as the system is not open for more than a few seconds, you probably do not have to evacuate. To test the switch, pull off the connector and short the terminals, the compressor should start.
Ken
1) Yes
2a) No
It's a very easy job, it takes longer to unclip the connector than it does to replace the sensor.
You'll hear a momentary PSSST when you unscrew the old one but don't worry about it. There's a schraeder valve (like a tire valve) under the sensor so unscrew it quickly and you'll minimize any refrigerant lost.
DEWFPO
Thanks.
Quick check..... Pull the connector off by pass the two wire in the harness with a paper clip. If the clutch cycles... Its either the system is low or the switch is bad..
Yeah, just take a small wrench and screw it off... It won't leak any out to speak of....
Jbo
