Long Ride, Bad Feul Economy
I drove my truck over 900 miles yesterday. I pulled a 5X9 open U haul trailer with a ramp. Empty to South Carolina from Central Florida, then back loaded with a motorcycle. It was incredibly windy, icy wind was blowing like crazy and apparently the trailer's tailgate acted like a sail - I figured I got only about 12 MPG pulling that trailer at 75 MPH, a little better coming back because the wind had died down somewhat. Also, pulling a loaded trailer was a lot better because the trailer never bounced as much as when towed empty. On the plus side, there was not one bug or fly anywhere on the front of my truck. After driving 900+ miles? Seems incredible. Insects surely do not like cold weather, especially cold wind.
Still I am amazed how high winds can kill your fuel economy. Under normal conditions, without a trailer I get around 18 MPG cruising at 75 MPH, and that is with A/C on. My A/C was off during the whole trip yesterday.
Even an open lowboy trailer will kill your mileage because it acts like an aerodynamic parachute. The flow of air behind the truck is as important as it is on the front - drag wise.
I pulled my 31' travel trailer from Charleston SC to Moses Lake Washington (2800 miles) a couple of months ago and averaged 8 to 10.5 MPG depending on the terrain and speed. Took lots of $$$$$
This Pic was from Moab Utah
Also... speed is a killer when towing. Towing a 7k lb (loaded) camper that is a huge wind sail, I still manage 10 to 11 mpg if I keep to 65 and slower. Into a headwind, it drops with wind speed so you have to slow down more, but does equally better w/ a tailwind.
It's good the know that this truck is capable of pulling a travel trailer this large. Id not think I would dare pull anything that heavy with mine that far. My truck is practically identical to yours, except it is a GMT800, without the AFM. The same engine, Z71, gear ratio, body style.
Did you pull the trailer in 3rd gear?
I remember your thread about rout possibilities.
You were kinda gutsy pulling it that far. Our trucks, if they were same model year, would have same tow rating despite my 3.42's. I tow a 5500# TT (hybrid) and wish I had 4.10's.
That said, I've learned to just be patient, tow in 3rd, watch trans temps, and I'll get there.
Do you have trans/engine temp monitors? what did you see?
Larry
Yup, colder weather + high winds + trailer will definitely have a major effect on fuel economy. Even just the cold weather seems to hamper my fuel economy driving around empty. I'm trying to figure out if it's the intake air temp that has the most effect. I realize 'cooler' temps improve power and efficiency with the density of oxygen increasing but at some point when it gets cold that must start to take away from efficiency.
I think that has to do with how long it takes the engine to heat up. Theoretically, if your engine was already heated to operating temp regardless of ambient temp, it would seem to me that gas mileage would be better in cooler ambient temps.
Here in the south, where very humid 90's-100's are not uncommon, I can tell that the truck is working harder on those days.
Larry
Larry
Yeah, 3rd most of the way, on good flat ground or slight downgrade I would switch to 4th (OD) but I would not allow the transmission to "hunt" between gears, if it started that I would just drop back down to 3rd and she was happy.
I ran between 65 to 70 MPH on the Interstate and the truck did great, remember that this was at Thanksgiving and the Temps were pretty low for the entire trip, my Transmission temp never got above 190 even on the longest grades.
The only thing I plan on changing before the trip back in July is to put some LT tires on (D or E Rated), right now it still has the stock P rated Bridgestones and I had a little more sidewall movement than I care for, I think the stiffer tires will remedy that. My 03 is actually a little more stable at 70 MPH with this same trailer than my 08 but the 03 has D rated LT tires so I hope that will be the cure.
Overall the truck did better than I could have asked for, I was worried about all of the mountains that I had to cross but even on the longest grades the 5.3L kept me at 50MPH (once or twice down to 45)
<open can of worms>
I didn't like the OEM Bridgestone Duelers. They wore out prematurely, too.
I now have E-rated BFG Rugged Trails, and believe this has helped as much as anything I've done for trailer sway. They were great in the ice and snow this year.
<close can of worms>
I want to buy a ProPride Hitch. Never would see trailer sway again. http://www.propridehitch.com
Larry
you "cold" problem is probably "winter formula" gas related
You're definitely right there. The "winter gas" also chips away at the economy.
Especially when all you can get is the #$%^@ 10% ethanol concoction. :shakehead:
Yeah, the cold weather kills mpgs. You figure the air is denser, so you have to plow through that denser air + crappy winter gas + wind + a frozen stiff truck that has to warm up to get to maximum efficiency. I got my 08 SD now about a month ago and I cannot crack 14mpg yet. Even been taking it easy on the accelerator and doing about 60% highway.
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 0 Anonymous, 460 Guests (See full list)
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
