Mirror Swap?
I have a 09 Silverado LT with power/heated/turn signal/power fold/auto dim driver side mirrors. The wife has a 08 Tahoe LS with power/heat only mirrors. The only diffrence in our switch housings it the fold on mine, her's is exactly the same except no fold switch. I'm thinking about getting towing mirrors and swaping my mirrors to the Tahoe. Question is what will and wont work on the Tahoe?
I can't give you a direct answer - but since no one else is answering you:
I did something similar to my 2003 Silverado.
The truck had power mirrors from the factory.
I installed the powerfold mirrors and a new control (on that model it was no extra button, but the control was still different and it mattered), and everything worked flawlessly without any other changes.
with that said, it sounds like you can swap over the mirrors and the switch and it should work fine. Just to be sure before ordering parts though I'd go ahead and take a Saturday and swap them over to test.
This has been disussed at length on this forum and no concrete answer seems to exist. The consensus seems to be that all the functions will work if you also swap the switch over with the mirrors. The biggest challenge in this swap is getting a new switch programmed to operate the power fold feature. If the vehicle wasn't originally equipped with power fold, the feature can't be "unlocked" by the GM programming tool. This info comes from a GM bulletin sent to dealers in regards to customers wanting to add the power fold feature. However, in your case, the switch is already programmed because it was in your truck. It should work fine. If you do a search on DL3 mirrors, you can find lots of info.
    • $4.35 85 oct.
    • For 2 years doing repairs or maintenance has not easy with my physical issues. Something simple isn't simple any more.      Sept. 6 2024 left shoulder 2 rotator cuff tears, bicep torn from bone. Still having issues, pain and dexterity problems left hand. Go to have EMG test on the 27th, second test. I'm left handed.   Oct. 3rd 2025 right hand carpal tunnel surgery and ulnar nerve,  end of 3 fingers still lack good feeling. Makes it difficult to do things.   March 3rd 2026, Cervical fusion, 4 vertebrae. Still have pain in neck and upper back.    I put upgraded shocks on our side by side, not hard but it took me over 2 hours. Oil changes are frustrating because nothing works like it used to.
    • 3.47 Kroger’s in Montgomery Tx
    • I can relate. 3 years ago I did that on my Avalanche. I was sore for a week. The only maintenance I do myself now is drop and fill on the transmission on my Honda’s. It’s just too easy. My yard work with my walks in the morning will be enough now I passed 70. The contributing factor is the heat in Texas. You just have to pace yourself.
    • I am sorry if this was misleading. That was a document attached to our most recent work order number (Doc# 7105804) that summarized all the current updates. These programs were ‘redone’ in the past but these versions dated 4/1/2016 were the ones that actually made all of the problems disappear. These programs were relayed to the dealer from the technical services group at GM. Here is the exact wording on the last work order:   “Front view camera reprogramming with SPS. A new version of FCM software was released to the service dept. In addition to providing general robustness and stability enhancements, this update includes all enhancements from previous software version releases. SPS camera and calibrate camera. OLH to perform extended camera relearn procedure after camera calibration. Would not take with first GDS learn. Front camera SPS – BDYZ333157450 GDS2 – camera road calibration performed 2810835 Front view camera reprogramming with SPS LT 0.6 OLH – extended camera relearn procedure OLH LT 1.5”   I got the truck back on 4/8 – since that time it has been great no problems whatsoever. The lane keep assist, active cruise control and AEB all work very well around town and at highway speeds up to 80mph. During this time I had been away for a week and purposely let the battery sit without a batter tender. Even with the battery a bit lower there were no problems exhibited. I really think this one has it fixed after dealing with these issues over a couple of years. These new programs and relearn process when completed seem to make all the parts (and newer replacement parts) ‘talk’ to each other without any glitches. Hope this helps
