Truck Shakes When Brakes Applied
hey guys need help, my dad has a 07 Chevy 2500 Hd and anytime he applies the brakes the whole truck shakes, i just recently purchased new brake and rotors for his truck and put them on and it still does the same thing. any help will be greatly appreciated i dont know much about these trucks
it is a fast vibration wether u hit the brakes hard of soft its the same and i did bleed the lines and the fliud is good
I'm heading to bed... so i'll throw this out there in case you do have aftermarket wheels.
99.99% of the time people put aftermarket wheels on a vehicle they forget to take the retaining washers off of the wheel studs. These washers are put on to keep rotors and drums in place on the assembly line and otherwise serve no functional purpose. OEM wheels have a chamfer on the back side to allow them to sit flush with the hub. Most aftermarket wheels do not have this chamfer... so they don't sit flush with the hub; and this results in a vibration when the brakes are applied.
So if you have aftermarket wheels on there... make sure these retaining washers are removed from front AND rear rotors/drums. Here's an image that shows a hub with retaining washers on two of the studs:
the wheels are the oem wheels and i got the pads and rotors from the same place and the match to the one that were one the truck,
Did you do the front only or the rear as well?
Did you torque them properly when you put the wheels back on or did you just crank down on them with an impact gun? (over torquing will warp rotors)
I had trouble with my 02. I put 2 or 3 sets of rotors on it and after 3 - 6 months they would warp again. I do not beat my truck. I had a conversation with a Rep. from Raybestos and he told me that the Ceramic pads were the cause of the problem. It seems that the pads are so hard that they permeate the rotors and cause hard spots in them. He suggested that I use metallic pads. I put a new set of rotors on and used the metallic pads and I haven't had a problem ever since.
Matt,What vehicles does this pertain to? I have never worried about this on any vehicle i've owned. I have a 2000 1500 that i have put on wheels with a electric impact without even thinking about using a torque wrench after. I recently replaced a rotor soon after i bought the truck. And i thing i did was tighten the piss out of the wheels because of a shake/vibration in the vehicle. But i always do the cross pattern when tightening. Regardless it is pretty mickey mouse,cause how many people have a torque wrench with them when they have a flat.
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
