Check Gauges Light 1992 Sierra
I have a 1992 Sierra with a 5.0 and recently the check guages light started coming on occasionally and when it did the temp. gauge and the oil psi gauge would quit working. Keep in mind this is the check gauges light not the check engine light. I tried pulling a code but that didn't help. Actually the temp. guage would nearly peg when the check gauges light came on. I replaced the thermostat even though a heat gun said the engine was at normal temp. I also have replaced the temp. sensor/sender? at the front of the intake manifold. Lately the check gauges light is on 100% of the time. The engine runs fine. Any suggestions? Thanks
Usually the check guage light comes on because of the swing on your other guages. Did your changes to the thermostat and sending unit work? Also, did you check the guage temp sending unit on the driver side of the motor? Is your oil pressure guage working correctly? The sending unit is down by the filter if I remember correctly.
--Mike
  • 10 months later...
I know it's been a while since I've been on this forum, been busy, still have problem. No, changing thermostat and sensor by thermostat didn't help. I agree check gages light is possibly on because of faulty sender but also wondering if it may be because of some computer malfunction? I both disconnected and grounded the temp. sender on side of engine, no change. One thing I haven't looked into is the oil sender. Will try that next unless someone has a better idea, but my oil and temp. guages are still pegged and don't move with key on or off but my fuel guage works.
--Mike
Check and see if you have a temp sending unit for the gauge itself. I have an 88 S-10 Blazer that exhibits the same problems. I replaced the temp sending unit in the head and it didn't clear up the problem. The ECM sensor in the intake was working fine and registering the correct engine temp
I am assuming the sender on the drivers side by the exhaust manifold is the guage sender, I both unhooked and grounded the wire with no change in the gauge. What puzzles me is that this problem affects both the oil and temp guages. Makes me think it is something other than senders or sensors but don't know where to look.
    • I can relate. 3 years ago I did that on my Avalanche. I was sore for a week. The only maintenance I do myself now is drop and fill on the transmission on my Honda’s. It’s just too easy. My yard work with my walks in the morning will be enough now I passed 70. The contributing factor is the heat in Texas. You just have to pace yourself.
    • I am sorry if this was misleading. That was a document attached to our most recent work order number (Doc# 7105804) that summarized all the current updates. These programs were ‘redone’ in the past but these versions dated 4/1/2016 were the ones that actually made all of the problems disappear. These programs were relayed to the dealer from the technical services group at GM. Here is the exact wording on the last work order:   “Front view camera reprogramming with SPS. A new version of FCM software was released to the service dept. In addition to providing general robustness and stability enhancements, this update includes all enhancements from previous software version releases. SPS camera and calibrate camera. OLH to perform extended camera relearn procedure after camera calibration. Would not take with first GDS learn. Front camera SPS – BDYZ333157450 GDS2 – camera road calibration performed 2810835 Front view camera reprogramming with SPS LT 0.6 OLH – extended camera relearn procedure OLH LT 1.5”   I got the truck back on 4/8 – since that time it has been great no problems whatsoever. The lane keep assist, active cruise control and AEB all work very well around town and at highway speeds up to 80mph. During this time I had been away for a week and purposely let the battery sit without a batter tender. Even with the battery a bit lower there were no problems exhibited. I really think this one has it fixed after dealing with these issues over a couple of years. These new programs and relearn process when completed seem to make all the parts (and newer replacement parts) ‘talk’ to each other without any glitches. Hope this helps
    • I turned 72 today. My day began with a trip to the pharmacy to pickup meds for me and the dog and then a stop at my chiropractor before heading home. Once home I started the job of replacing the rear brake pads and one rotor on our 2018 Silverado which will probably end up taking me 3 days to finish, gotta pace myself you know. Sometimes I question myself on why I still do most of my own repairs but if I wasn't then it's more than likely I would be sitting in front of the TV all day. It seems like the list of things I need to do gets longer no matter what I accomplish. I'm not complaining but being retired was so much easier when I was 62.   Peace
    • google "bathub failure curve". Basically, any part of the vehicle can fail at any time.  It starts off as being more likely (early failure), then the failure rate goes down (but does not go to zero), then it goes up over time because it wears/ages out.
    • I went from every other day to about once in five since the rain abated. I'm not unhappy about that. Took most of the month for the ditches to dry enough to mow.
