Name That Sound.....
Ok so I did some searching on the forum and could not come up with something similar to help me out. I was wondering if anyone had any input.
I have a squeak that is coming from the passenger side of the truck behind the cab somewhere. I only hear it when driving over bumps in the road (small or large it doesn't matter) and it sounds like a rattle/squeak sound. I cannot duplicate the sound when I shake the truck and I crawled under the truck and shook everything I could think of and still could not duplicate it. I know it is coming from the outside because I had the windows down the other day and it was even louder than normal.
The only thing under the truck that was making noise when I shook it was the rear passenger side strut which was making a loud squishing sound (did not sound normal). Could this be the noise?
I thought at first it was a loose bed mount but I had some work performed last week where they took the bed off and set it back on so I am certain everything is tight there.
Any help would be appreciated!
You have an extended cab right. If so I think it's the cab making the noise, mine does it and I've taken it to the dealership but nothing. I've read on here that putting something on the trim around the doors makes it go away.
Get someone (preferably hefty) to bounce on your bumper whilst you're underneath to ID the location.
My '03 Silverado had a prominent squeak (but no rattle noise) when new that drove me crazy. Went away in wet weather.
Finally determined it was one of the body mount bushings.
Unbolted it, jacked up bed a bit, liberal application of silicone grease, and it's been quiet ever since.
IF you have nerf/side step bars, check to see if there's at least 1/4" clearance between the body mount pockets and the bar mount brackets. Contact here could cause a "creaking" sound when moving/flexing.
You sure it's not just the movement of your Leaf springs? Try a little lubrication between the leafs on your rear suspension. Mine did that until I shot some silicone spray in there and it stopped...
I think I found it guys....
I was playing around with the latches to my bed cover and it turns out it was the latch rubbing on the catch metal to metal. I put some bearing grease on them and the sound went away. Now I want to get some better grease that will not turn to water when the sun is beating on it.
Thanks for the suggestions. I spent a good couple of hours this evening searching all of the possibilities.
Also, now that I have fixed that, I am still worried about the strut that was making the squishing noise... Is that normal?
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
