Gmt900 - Question Re: Aftermarket Rear-view Cameras
Hey guys,
I've been looking at various rear-view cameras for my '08 Sierra, trying to find one to fit in the factory tailgate handle bezel (I bought one designed for the factory camera). The one thing that has tripped me up so far is that I'm trying to figure out how to wire the camera so that I can still remove the tailgate if needed (I've had to take it off a few times when hauling stuff).
Anyone here have a solution, or done this sort of thing on their trucks? I know I could always find a different mounting location but to me it seems like having it on the tailgate handle is the best place for a good viewing angle. Maybe it's too much hassle to try doing it that way though. :D
Thanks for any suggestions/ideas! :thumbs:
Use a connector like a 4way trailer connector so you can mount the truck side to the truck.
Hey guys,
My coworker bought one of those Walmart rear view cameras that mount on the license plate. It is a very inconspicuous mount and works surprisingly well.
I thought about that, but I haven't seen a weatherproof connector so far that would be small enough to fit in the gap between the tailgate and the truck and still have enough terminals to carry the power and video signals properly.... :thumbs:
Hmm... I'd seen something similar from Painless wiring; I'm just not sure if those would wind up being visible when the tailgate is on and closed (due to size). So far those do look to be the best option though!
It looks like there are several other options to consider on that site though.... thanks for the link!
I don't know if you've looked at the factory camera itself, but it's got connectors that're fairly easy to unplug in order to remove the tailgate. You just unscrew the rear license plate, unplug two connectors wires that're behind it (and plug the two open ends that're left on the truck into themselves to prevent any contamination), feed those wires back up through the bed to the tailgate, and then remove the tailgate as normal. Haven't done it yet on mine, but it looks pretty quick and painless.
Even if you don't use the factory camera, I'd imagine you could use the connectors in the links above and locate them behind the license plate in that same spot too so they're out of view and have plenty of room.
While we are on this subject. Who has found an aftermarket camara that fits well into the tailgate handel bezel? Post up links if you have them.
Thanks,
Mike
No, I hadn't seen how the factory camera connects. I hadn't even thought about locating the plugs behind the license plate, but that sounds like it might be the ticket!
Thanks for the suggestion... guess I'll have to order some of those weatherpak connectors and give it a go. :thumbs:
Thanks,
Mike
The camera I'm most likely going with is the Boyo VTK-350; I've seen a few other guys on this site use that camera in the factory handle bezel with good results. Here's a couple pics from another member (blackgold) who installed one on his truck:
Just google it, the same camera is available from several different sources.
    • HD at the moment, are kinda their own deal.  How LTZ sells on those vs on 1500, there is a difference.   They are merging most of the mid trims on 1500.  LT, RST and LTZ are replaced by one trim, Silverado.  LT and RST are a BIG portion of sales.    Bad naming choice aside, the new Silverado trim will offer the spread of options that those three trims offered.  So expect to see things like the tech package for example, and memory seats.  And LT Trail Boss will now just be "Trail Boss" (formerly LT Trail Boss) but will offer content spread like the new Silverado trim will.  The press photos showed the Trail Boss (formerly LT Trail Boss) has access to Super Cruise now, which on the current truck was High Country only.       Here is the Trail Boss interior.  Memory seats and Super Cruise are present.  All things the LT Trail Boss it replaces, and the RST it was based on didn't get on the current gen.  You had to go to LTZ or ZR2 for memory seats, and High Country for Super Cruise.
    • I installed a Hellwig rear sway bar on my 21 Sierra SLT, it made a huge difference on how the truck handles, no body roll, the trucks much more planted now. Not sure of the suspension differences between the 21 and 26,  if its body roll your having a sway bar will solve it.
    • So a follow up and my fix. I found in online searches the live data to look at on a scan tool to verify the fuel tank pressure sensor was working.  It showed an spec number towards the lower end of the rang, but in spec.  Then while it was running opened the gas cap and the pressure should change.  It didn't change even a tiny bit.  The data for the purge valve said it was open...never changed. So then I measured the voltages on the plug for the fuel pressure sensor and they matched what it should be.  So local car quest parts had the sensor in stock...it was a bit of a pain to remove and an even bigger one to get it to actually go back in.  It helped to unbolt the driveshaft and bungie cord away from the gas tank to give a bit more room to work. So fuel tank pressure sensor in I cleared the code, and started it up.  I went to the scan tool's live data and... Eureka! The pressure number was different and fluctuated a bit.  So took it on a short drive and pressure number varied saw the purge valve go from closed to open and back to closed.  Drove it to and from work for roughly a week plugged in the scan tool no codes.  I took it in to get tested and passed.  In my state's infinite wisdom (oops meant greed), since I pushed the test with the maximum extensions I have to take it back in by Feb '27 to 'get it back up to date', then my next test won't be until Feb '29.
    • Any grease on the stud threads of any kind?   Wheel studs should have NOTHING on them for proper torquing and so the nuts don't back off.     Are all of the mating surfaces clean?  So wheel, rotor and hub?     We've had plenty of trucks at work with that wheel, this is a first to me.  Makes me think they've got a lube tech putting anti-seize on all the wheel studs or some kind of grease, and they need to stop doing that.  To have 11 other trucks with the same exact problem.
    • I was a Chevy guy for years, then switched to GMC because I liked the looks better.  I'm actually thinking I like the Chevy looks better than GMC for the first time in a lot of years.   One thing I know for certain, the new GMC dash is hideous!  Chevy wins this one!
