Spongy Brake Pedal
Just tonight after fueling up at a gas station, I started my truck up and at the first stop sign my brake pedal went almost all the way to the floor, it was real spongy and not firm at all like usual. I can still stop, but I find that I have to pump the brakes to stop because once the pedal reaches a certain point it gets real soft and doesn't stop quick at all. As soon as it reached a certain point, a red light that says BRAKE on the bottom of my tach came on and also a message that read SERVICE BRAKE SYSTEM on my DIC. What could be causing this? I have disc brakes on all four wheels. A buddy of mine once had the same problem on an older ('98) silverado and he said it came out to be the master cylinder went bad? Does this sound right? Any ideas are greatly appreciated! Thanks
It was just flushed about a month ago. I didn't have time to check the fluid level last night, this morning I did though and it is down about half of what it should be. It was just full saturday because I changed oil and checked it then. So now I am thinking that I'm dealing with a leak somewhere. Could a line be rusted through leaking fluid causing me to lose pedal? that would explain the loss of fluid. Now that I have determined that it IS low on fluid, I think I can rule out the master cylinder. Anyone have any ideas? Thanks
A spongy pedal could simply mean that there is air trapped in the system. I would bleed the brkaes again to eliminate this possibility.
Ok, I will check the bleeders and bleed it again. But why would it have worked fine up until now for the past month? I may trace all of the lines just to make sure none of them are leaking anywhere. If I do come across a leaky line, is the best way to fix it to splice in a new piece of line, or should I run a whole new line from the proportioning valve? Thanks for your advice
went out and checked everything over, found the problem. The brake line for the right rear wheel that runs along the rear end is leaking real bad about right in the middle of the line. Should be an easy fix, since that particular line connects right above the rear end and also over at the wheel. I plan to bleed both rear brakes when I get it fixed, will I need to bleed the front too or will they be fine since the leak is at the back? Thanks!
If you are replacing brake lines, then replace them all and if you can afford it, upgrade to ss braided brake lines...
Bleed them all, starting from the farthest from the master cylinder and then work your way progressively closer to the one closest to the master cylinder.
    • In most areas of the country, wages have trailed CPI increases over time (let's say, since the 70's) and things like housing, energy, and food have vastly outpaced wages on the whole. Can't ignore that, it's very real.   That isn't to say there aren't ways to live in ways that mitigate some of that, including moving to cheaper areas of the country. In KNut's neck of the world, median housing prices in "nearby" Dallas are more like $500k. If you're raising a family and young in a successful career, your economic opportunities are probably going to be better living closer to Dallas than Cornhole. A 3 hour (6+ round trip) daily commute probably isn't tolerable for most folks. Grumpy mentioned economic migration; but we've seen what happens when people populate and grow an area. It becomes more expensive when economic opportunities come to roost.   One thing different now from back in the 70's is our quality and standard of living has changed. Healthcare is light years better, for example. But it's also much more expensive. And we have communication and information/tech tools that folks in the 70's could never imagine, and they're accessible to people of just about all incomes. Cars are light years safer, faster, and filled with tech advances. Homes are larger, more energy-efficient, and more luxurious on the whole, from starter homes to luxury homes.   Seattle was once affordable. My folks came here in the 70's with a lot of other people from California looking to escape uncontrolled sprawl, smog, and rising prices in the Bay Area. Seattle and the surrounding area has grown considerably; The home they bought for, I think it was $70k or $80k in the late 70's is now worth $1.2M today. The same house.   So while there have been obvious boosts in some areas of quality and standard of living, regarding opportunity, that's a bit more nuanced. It's really not possible for young people to get started in similar situations in areas of the country that have become "HCOL" (high cost of living). There are many more areas than before, which is to say they exclude younger workers or make their lives significantly harder. They have to commute farther and longer to afford to live in the area. They have to take outsized risk, take on more debt, significantly delay family planning. Or, they could move somewhere cheaper, but there's usually a loss of economic opportunity that comes with that. Even for the same job, it may pay a lot less in a LCOL.   What I don't like are Boomers with phones thinking they have all the answers and outright saying that if people stopped paying for their cell phone that they'd be rich. It's as stupid and misguided as people who think they'd only be rich if taxes weren't so high. Sorry guys, Elon proved you wrong on that one, I guess you're just lazy and blaming your own situation for the reason you're not wealthy. Mobile communication is basically an expectation in a modern society and workforce and it's often cheaper than having a copper landline these days, so... What's your point?
    • My 2008 started exhibiting similar symptoms, wasn't 'cold' enough. I went through a pretty extensive diagnostic process for a DIY'er with limited OBD access. System evacuation and recharge included.   Noticed one day the passenger side was cold (I'm never over there so took awhile to notice).   Pulled the drivers side blend door actuator out, disassembled it and cleaned it out. Put it back in and did some kind of reset and it fixed the problem.   Long story short, it wasn't the A/C system at fault, the blend door wasn't moving to full cold position.
    • Just got in two back to back road trips of about 700 miles each with my new 2026 2500HD trail boss.  Really nice highway cruiser. Two very different trips - both loaded with gear for my band. First trip was to Durango for an event with Indian Motorcycle - saw some really nice bikes while out there! All mountain driving on back country highways - very pretty scenery - lots of hills along the way including a crazy pass that went up to 11,000 feet! Overall MPG for that trip was 15, speeds were typically 60-70 range depending on road.   This past weekend was into rural Nebraska, so mostly fast interstate (76 and 80) with some fast 2 lane getting to / from the final destination outside of North Platt. Speeds mostly ~80.  Also mostly flat although somehow dropped from 5K to 3K feet and then back up getting back into CO - didn't really notice it was subtle probably over a long distance. Overall MPG for the trip was 14.   Truck is still barely broken in - just got past 2K miles on the second trip. We survived some torrential thunderstorms in NE on Sat. night - especially driving to the hotel after the gig at 1AM.  Truck didn't skip a beat - I think the weight of these HD trucks really reduces the hydroplane chances.   All good - made it back to Denver area mid day on Sunday for fathers day.   I did a quick calculation to compare MPG and overall trip cost to my previous truck, a 2018 Colorado V6.  From previous experience I would have expected to see a 4mpg improvement on both trips.  Based on current gas prices which are starting to come down but still $0.75 to $1 higher than they should be based on barrel pricing, each trip was about $40 more.  Really not much of a concern in the grand scheme of things I must say.
    • Thank you very much for this info. I will start looking for a 5.3L. I have viewed several Youtube video and get so confuse. You are the first person to give good advice.  Thanks again, John
    • ?   What exactly is your question?
