I just ordered new gunner 6 chrome rims and new tires. I will only be running these in the summer and the stock ones in the winter. what is a good way to clean them? What type of product should I use? and my main Question how do i prevent PEELING or PITTING? Any ideas
Thanks
Brandon
If they are indeed chrome, a good chrome wheel cleaner like Meguiar's Hot Rims Chrome Wheel cleaner is a good start. Follow with a coat of wax of your choice (I use Meguiar's M21 or NXT)
Make sure they are not chromed then clear coated as some chrome wheel cleaners are too aggressive for clear coats.
If they are not dirty or major brake dust, then just a good soaping with your car wash should work in a pinch.
If you use a wheel cleaner, most of them strip the wax and will need to be waxed again.
Find out from the manufacturer if they are chromed or chromed and clear coated. Clear coat is just like paint (most.....) and can be treated as paint (even clay them).
I like poorboys wheel sealant.
www.poorboysworld.com
Even on my curent chrome clads or any other wheel i want to keep nice I use seperate bucket with as hot of water as I can stand to have my hand in. I have some very soft brushes and micro fiber cloths. I wash the wheels with dawn dish soap which cuts through grease and junk.
I then dry them off and wipe down with micro fiber and then give them a wax with some spray on NXT. It's easy, cheap and very effective. They get waxed at each cleaning and the NXT does build up or cause white junk to build up or chalking.
I use this method on chrome, steel, painted, cleared but not on machined. Machined I used hot soapy water and the cleaning brushes minus the wax.
Alright thanks another concern is i wash my truck about once everyweek do i need to take the rims off to clean in behind them or will the brake dust cause peeling also? Or should waxing front and back before i put them on and then again when i take them off before winter suffice.
Thanks
Brandon
I use Mother's Wheel Cleaner paste as they work on both chrome and clearcoated alloy wheels and then as has been suggested, coat with some wax. I used Meguiar's NXT myself and it works and lasts quite well.
I do not use any fancy chemicals....... Just plain old 3M car wash soap(i think the bottle says Car Shampoo thou). Or some high pressure car was soap from my car wash (only put 1 small spoon full in you know that LONG spoon your wife gives ya to eat your cereal with sometimes haha).
Dish washing detergent removes wax at a faster rate, than car wash soap. At least twice a year I wax my rims (front and back side).... It helps getting off brake dust.... I learned that before ceramics came on the market for light vehicles.... If they are waxed the brake dust comes OFF MUCH easier!!
Jbo
That is why I use detergent and it's dawn to boot. It also removes grease, grime, road salts and other stuff and with the NXT i can wax and shine up a wheel in just minute or two.
Yes I would recommend taking the wheels off and cleaning the inside, I do this once a year for my own truck. All kinds of crud accumulates back there!!!!
A simple solution is also a microfiber and some Stoner's Invisible Glass (Or any glass cleaner). My 95 Impala SS has chrome stock wheels and it doesn't get that dirty, but after the wash I go around to each wheel with glass cleaner and a microfiber, makes em look like glass :dunno: . I NEVER, and would never suggest you use wheel cleaner. When I got my wheels chromed the owner of the place strongly suggested never to use any of the sort, just because some of them do affect the clear coat even if they say they don't. And from the sound of it you wash your truck enough to not have to worry about any serious build up.
windex, you wouldn't believe how good it works... super mild abrasive, used it for decades.
Windex.... I would compare it to WD-40 in terms of multiple uses.............. Seems their are more than just glass uses for that blue fluid.....
Just do not get the bright idea to use it in your washer fluid as a complete replacement. It will KILL the rubber in the blades..
Jbo
    • I really appreciate the response.  I guess I was confused about torque angle vs torque angle yield.  The individual bolts don't have a warning on reuse but the part number for the LCA nuts does.   Regarding the purpose of the moog grease fittings on their bolts .. Guessing to reduce possibility of corrosion locking the cams or seizing to the bushing inserts.
    • The top speed is software limited, I don't think there's a way to change it without de-doing the whole truck. If you can get a CAN log per my above post we can try seeing if there's anything obvious going on. What happens when you plug the truck in to charge it, does it ever fully charge up or does it stay at low battery %?
    • The LCA bolts are NOT a one time use fastener.  GM does not have them called out as such at all.   They are torque plus degree, but not a one time use TTY.  Nowhere in the service manual does it call out for replacing the LCA bolts for being one time use.  The factory spec would apply to the Moog bolts as well.    I see two things different.  The Moog bolts are greaseable (which I see no point in) and they don't have one of the washers welded to the bolt like the factory bolts, so they can be used in all 4 positions.      Think about it.  The LCA bolts are now the alignment adjustment point, instead of the UCA bolts like the prior generation.  A bolt that is meant to be adjusted for alignment...would it make sense to make it a one time use component?  How would you get an alignment done in the first place?  You couldn't.       Also.  What TSB exactly?  There is no TSB that I see for 2019-2026 for over-torquing LCA bolts.  There was a PI, PIT5533C, but that covered 2014-2018 body trucks for re-torquing LCA mounting bolts.  But those trucks to a 2019-2026?  Not the same, so PIT5533C does not apply.
    • Nice looking setup!  Is this the kit you got?  If so 211 is a great deal!  https://accessories.chevrolet.com/product/trailering-camera-system-86584184   My TT came with a wireless rear camera but it only works on an app or a separate screen they sell so I've decide it's not worth the hassle since it keeps disconnecting and with wireless android auto it's a hassle trying to connect my phone to it.  So I've been thinking about adding the GM camera so it's integrated into the rest of the camera views.   I also found this one which seems to be a different PN & retail price that explicitly states the invisible trailer view https://www.shopchevyparts.com/chevrolet/2024/silverado-2500-hd/electronics/85825715-silverado-2500-trailer-camera-transparent-view-requires-trg-camera-provisions-p-92326971.html?sort=2a
