Welcome Jeff. I spent a year down in the Carnation city for school.
Where did you go? Mount Union. The mighty Purple Raiders.
Up North in Cleveland Jeff, but enjoy the trip. I hate that Cincy/Northern KY airport. I spent an overnight there a few years back when the fine folks at our airport here assured me my connection down there would also be delayed due to storms coming from down that way. Well, sure enough, get in Cincy and the plane had left.
  • 6 months later...
  • 6 months later...
I'm near St Paris, which is north of Springfield, which is east of Dayton.
Sounds like I've got a few around me!
  • 6 months later...
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
    • I had a boat for many years, never had a problem even with a 2 wheel drive 93 Silvy for 20 years. Good tires, proper use of the gas pedal worked.
