Vin /build Sheet
Greetings from a newbie! I am told that there may be a compassionate member who can get me a build sheet/repair record for my new 2007 Yukon XL 2500,vin#,1GKGK26K87R243692. Can anybody help me? Thanks for your consideration!
Bob
Bob
A dealer can easily print this out for you too.
Bob
+1 on the dealer
Bob
Thanks!!!
Bob
Thanks!!!!!!!!!
