Installing A Sub In 2005 Sierra
i did research on this, and found out that i need a line out convertor to hook up a sub and amp to my stock headunit? has anyone does this on this truck, or similar year? is it easy? otherwise someone said something about splicing into the rear speakers with the rca cables. would this be easier? where are the speaker wires running? in the door? thanks for any help!
You don't need a line-out(low voltage converter) unless your amp only accepts RCAs as inputs. The easiest way to wire the amp I could think of off the top of my head is to find where your rear speaker wires are under your driver and passenger door sill plates and tap into them there and bring to the amp in the back and hook them to the amp's high level input, not RCAs. The high current at the speaker, if fed into RCAs will burn up the amp. If your amp does not have a connector for high level input you WILL have to purchase a step-down converter to hook up to the RCAs. Keep in mind that all this is based on you not having the bose system, if you do it's a whole other story. :jester:
Doesn't the stock H/U have RCA's in the rears. If so then your set. But a quality H/U isn't that expensive and it will allow you to tune the sound to your liking, instead of "Rock/Pop/Classical/etc".
A few tips:
Run the power cables and RCA cables down opposite sides of the truck (to avoid interference)
Use a clean metal surface to ground the AMP
Use the Blue "Antenna" cable on your wiring harness to power your AMP on and off when your truck's on
Good Luck!
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
    • Looks nice. I still have my 2000, 1500. Bought a 2025, 1500 for retirement. Feels solid. These trucks have a bad rap on the internet. My brother has a `24 1500, 5.3 with 52,000 miles. No problems at all. Mine hasn`t either but mine`s only at 12,700 miles. Have seen some of these things with 100,000 miles with no problems.
