Anyone Running 17" Chrome Or Black Rims..
wolverine_22
I was just wanting some pictures...of some 17" chrome or black rims on the trucks...Been looking at rims...dunno if i should stay at 17...since i have a set of tires...or go to an 18 or 20...
imo keep 17s. the more sidewall the better. also, its not really the rim diameter that limits the tire height, its the rim width (they make 44" swamppers to fit 15s for example). as you go taller you need to go wider too. my truck is on 17 inch rims with a 34 inch tire (in my sig)
like a 17x9???
thats what i went with, but i also dont like low profile tires on a truck. the rim width you need also depends on the manufacturer. usually each tire company's site will post the suggested rim widths for their tires. for my nitto terra grapplers, nitto says anything from a 8-9.5" wide rim will fit their 305/70/17. i could also fit 265/70/17 (32- stock), 285/70/17 (33), or a 325/70/17 (35") on a 17x9. but this changes from tire to tire and for my piece of mind i try to stay in the middle of the approved rim width range that they give. id check each tire site first and decide what tire you want and then choose the wheel size to fit the tire. here's the nitto page for their terra grapplers to refer to:
http://www.nittotire.com/#index%2Etire%2Et...rappler%2Esizes
what size wheels you have stock? and what tires do you already have? they may already fit your wheels.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
