Hello & Here We Go...
I've had this truck for almost a year now and I finally found a truck forum worth joining. It's a 2009 GMC Sierra 1500 4WD SLE Extended Cab - Standard Bed, Onyx Black, Ebony Cloth Interior, 5.3 V-8 w/AFM, 4-Speed Auto, 3.73 Rear Axle Ratio, SLE Preferred Package, Convenience Package, All-Terrain Package (includes Z71 Package & HD Trailering Equipment), 6" Tubular Chromed Assist Steps. I've added GM Front & Rear Splash Guards, GM Wheel House Liners, GM Premium Cloth Hard Folding Tonneau Cover, GM Bedliner & Tailgate Liner, GM Bed Rail Protectors, GM Polished Exhaust Tip, GM Under Seat Storage Organizer, GM Heated Seat Kit, and McGard Locking Lug Nuts. I'm trying not to violate the warranty for the time being but I'll be making changes soon enough. This forum has given me plenty of ideas and tips and I plan to keep this truck for a long time.
Welcome to the forum and nice looking truck! As always, great to see another All Terrain guy here.
    • Correct.  2019-2020 are serviced by a different p/n.  19420611.   The recall engines 2021-2024 are serviced with 12740076.     What the difference is between the two, I'm not sure, but 2019-2020 only show 19420611 as the replacement engine p/n.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
