Help Me Find "smooth Ride" Shocks
I've got a 2003 GMC Yukon SLT with the smooth ride option. Not a denali - and not air suspension.
Im looking to replace the shocks since they are not so "smooth" anymore (89k on the truck).
The problem is - I cant find the "smooth ride" shocks anywhere. I was hoping to get some at a local parts store - but they dont list that option. DO I have to go to a GMC dealer to get this exact shock? I dont want the ride to be worse by putting in the wrong shocks.
Im not a fan of bilsteins or ranchos if that helps.
thanks!
Do you have the ZW7 package? (Smooth ride w/auto rear leveling) If you're not sure, check the glove box for the RPO code sticker and see if ZW7 is one of them.
You'll probably want to go with Monroe Sensa-trac's... they're comfortable/smooth shocks
I agree on the recommendation for Monroe Sensa-Trac as a switch over from the GM smooth ride option....
Thanks guys. This is really helpful. I'll check the codes again in my glovebox to be sure. Thanks again.
Monroe E-Catalog
Passenger Cars and Light Trucks - Ride Control Section
GMC
2003 - Yukon - 2 W.D.
2001 - 2006 4 Door w/ ZW7 Premium Smooth Ride Suspension (Self-Leveling Rear Suspension Nivomat) - Exc.w/ Z55 Autoride Suspension
Need help deciding which of Monroe's product lines is right for the way you use your vehicle?
Highlighted part numbers indicate premium products.
Front 37178 SENSA-TRAC® TRUCK SHOCK ABSORBERS
911178 REFLEX™ TRUCK SHOCK ABSORBERS
34501 GAS-MAGNUM® SHOCK
32347 MONRO-MATIC PLUS® SHOCK
Rear 40210 SPECIALTY SHOCK ABSORBERS
________________________________________________________________________________
__
Monroe E-Catalog
GMC
2001 - 2006 4 Door w/ Z55 Autoride Suspension - Exc.Luxury Edition
Front 40044 SPECIALTY SHOCK ABSORBERS
Rear 40034 SPECIALTY SHOCK ABSORBERS
_______
Monroe E-Catalog
GMC
2001 - 2006 4 Door Luxury Edition w/ Z55 Autoride Suspension
_______
Monroe E-Catalog
GMC
2001 - 2006 All 4 Door - Exc.w/ Z55 Autoride Suspension or ZW7 Premium Smooth Ride Suspension (Self-Leveling Rear Suspension Nivomat)
For Performance - Mono-Tube
911505 REFLEX™ MONOTUBE SHOCK ABSORBERS
Rear 37166 SENSA-TRAC® TRUCK SHOCK ABSORBERS
For Towing and Hauling
58639 SENSA-TRAC® LOAD ADJUSTING SHOCK ABSORBERS
911166 REFLEX™ TRUCK SHOCK ABSORBERS
911506 REFLEX™ MONOTUBE SHOCK ABSORBERS
34692 GAS-MAGNUM® SHOCK
32348 MONRO-MATIC PLUS® SHOCK
_______
Use Compnine to get your RPO Code....
Hope it helps..... I really like my Reflex MonoTube shocks.... And everybody I have sold them to likes them.....
Jbo
