Debadged Finally
I finally completed the de-badging and snapped a couple pics. Next pictures will be with the 3" Body lift, and 295/70/17's, and hopefully the tow mirrors from a certain member. :P
Current setup is Bilstiens at top notch and 1" block in back.
Looks good. I was thinking of going with 295/70/17's next go around and either going 1.5" BL or just trimming to fit. Can't wait to see pictures of the tires and BL
I actually like them on the Stealth Gray. I would have to see one without it to make up my mind. Z only blends on the Passenger side. Funny I never noticed that before. Thanks now it will bug me :P
Only bad thing about the 295/70/17 is you are limited to Nitto Terra's or Trail, Toyo Mud, Cooper SST's, or Hanook ???.
Yeah but if you trim right it's not noticeable at all or if I go 1.5" BL it doesn't look bad with 33's either. I'm still real undecided but I just got new tires so it'll be awhile
hey brian when you throw your dirtbike in the back of your truck can you close your tail gate all the way with the bike tied down centered in the bed. I know its off topic but I was wondering. Nice truck by the way looks clean.
Looks good. Where did you get that rear bumper at? That thing is sweet.
Thanks, It is a FAB FOURS bumper. They are out of Charlotte NC.
A 450 will not fit centered in the bed. It is off by about 3 inches. Wish it did. If you tuck the front end in the corner the rear is only about 6 inches from the bedside at an angle. Not bad at all. It is a regular box.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
