2009 6.0 Handheld Tuner
Hello everyone. I have done a few searches over the past few days and read numerous threads on various tuners. I was not able to get what I was looking for. It seems the majority of the threads are addressing the 5.3 or if its the 6.0 its other years besides the 2009.
Have any of you had any experience with handheld tuners on a 09 Silverado 1500 with the 6.0 and 6 speed? I have looked at the different makes and some dont even list the truck. I fear they may never since they are now using the 6.2 engine and they only list up to 2008 for the 6.0.
I thought about a custom tune however I wanted to try the handheld route first if possible. Has anyone any experience with a 2009 and 6.0 in a 1500 with a handheld tuner like a Diable or a SuperChips?
I believe you will be happier with a custom tune. With the release of EFIlive Autocal you change tunes on your truck easily. Check out the Black Bear Performance forum.
Black Bear
Or their website: Black Bear Performance
If your set on a hand held, I'd look at the Diablo
id call up superchips and ask them if the Cortex works on your engine/trans combo. They're currently the only handheld that allows the user to adjust 6spd trans parameters (im not sure as to what extent though).
I read that also in another thread and it has me wanting to call them. I actually called at 8a.m. est and no one answered so I will wait a few hours. They are only listing the 5.3 at this time.
As for the blackbear autocal..thats a great product I dont doubt it at all. However it appears to be more than I want to spend at this time. I have a message in to them about it and I am waiting to hear back from them. I was on the list to get notified when it came out.
if you go through the different applications, the cortex does work on 6.0 and 6.2L engines as well as combinations with the 6spd (6.2L with 6spd in the Yukon Denali and 5.3L with 6spd on newer trucks). So i'd think it has the capabilities to do the 6.0L with 6spd combo and maybe its just not specifically listed on the site....
so there is hope :cool:
I just got off the phone with them..no hope. Its not for the 6.0 at all. They said they cant get any of that configuration for testing. I did get a call back from Hypertech about theirs also. They do make one for the 6.0 six speed 1500's built in 2009. It also states it can change shiftpoints and firmness. I will do more research on this one.
actually... the application guide for the Cortex-2950 does list gmt900 2500-3500 series trucks, both gas and diesel...... it just doesnt come up in the drop down list when using the vehicle search guide.
edit, just saw your reply... booo
I saw that also. However, my truck is a 1500 with what they call the "y" motor or high output version. Its not a 2500 with the other 6.0 they make.
The U7194 Predator supports your 6.0, as does the Trinity T1000m which will have full TCM capability in the near future.
Exactly how long has that claim been made? Since 2007? You guys have suffered a serious loss of credibility!
No current handheld (other than the AutoCal) can tune the 6spd TCMs.
Superchips has TCM support. I know that to be a fact. My 09 Silverado has the 6L80E and my Cortex will make adjustments to the TCM. My friend tried my Cortex out on his 4speed gmt900 and it worked for the TCM in it as well.
I have read hypertech has TCM support also but cannot verify that.
What adjustments does it make to the TCM on the 6spd? I do know they support the 4spd.
Last I heard was that they were still looking into calibrations:
SuperChips
More SuperChips
I could have been wrong, and just going off of the info I have that they don't support any 2010s yet.
It will adjust shift points from 1st thru 4th. It will also adjust shift torque (shift firmness). The tuning makes the shifts snappier but there is no end user adjustment for that. I have also been told they are recalibrating the transmission tuning on the 6 speeds. I am unsure if they will provide more end user adjustments or not.
Exactly:
They are in the process of recalibrating the TCM tuning. I felt some of the downshifts were a bit harsh. But they assured me they are recalibrating the TCM. So hopefully I will get some more end user adjustments.
I found a work around to achieve higher shift points with stock shift speed and stock shift torque until their new calibrations are released.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
