Wanted Splash Guard/rock Guards For 90's Gm 4x4
Wanted splash guard/rock guards for 90's GM 4x4
WTB heavy duty 2" receiver hitch/Reese hitch for the 94 3500
Are they all the same as far as the mounting brackets?
I need 2 front splash guards/rock guards for a 95 K1500 Suburban & a 94 K3500 truck. Both the same. I'd prefer aluminum but I'll take what I can find.
This is the guard that goes from frame rail to frame rail - from the radiator to the cross member. It covers the pitman arm assembly.
I also need the rock guard for the front differential for the 94 K3500.
I'm pretty sure they are all the same.
Still need a green rust free drivers door for the 1995 Tahoe.
A tan drivers side sun visor for the 1996 Suburban.
An aluminum tailgate cover for the 1994 crew cab.
The tube type Nerf bars for a 90's GM crew cab like these
http://www.realtruck.com/dee-zee-ova...1620P1C1T.html
OEM style 90's Radio knobs. The volume knob in particular.
A good PMD for a 6.5 diesel.
A 97 + air filter box, K47 style.
3.42 geared front and rear differentials for our 1998 K2500 6.5 diesel Suburban.
Would trade our 3.73's
NP246 transfer case 1998 - 2002. 32 spline Autotrak for the 1998 K2500 Suburban to bolt to a L480E transmission.
Aftermarket Engine oil cooler lines or kit for a 6.5 Turbo Diesel.
Front and rear differentials with 3.42 gears or higher for our 1995 2 door Tahoe.
Have 3.73 gears now that I would be willing to trade or sell after I make the swap.
Clean headlights for a 90's GM truck.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
