New From Jersey
HollowWatcher
Hey Guys, Great site you have here. I am looking at getting a 6.2 Silverado EC or CC 4X4. Do you guys think I should get a 2010 or a 2011? I want to try to get the best deal possible. Thanks.
alright another jersey guy.
Where abouts are you from?
I'd call around or do some dealer searches to see what's available... get either the 2010 or 2011 that has the options you want and at the best price.
