Towing A Trailer With My Silverado
We are planning a trip with our Silverado and want to tow a trailer. I am looking in the owners manual about the trailer wiring.
It says for each of the trailering packages that the wiring is tied to the frame by the spare tire. (I remember my 02 Silverado was like that and I had to wire up the plug when I installed the trailer hitch)
My 09 truck has the trailering package with HD suspension and it has a plug in the bumper with a circular pin plug.
I guess I am going to have to crawl under the truck and see if it is wired up since the owners manual doesn't say anything about it being pre-wired.
Anyone have any ideas on this?
Do auto parts stores have a trailer plug adapter for this so I can wire up a trailer that already has a 5 wire plug?
Yes, your truck should be wired already to use an adapter to whatever is on the trailer. Wal-mart should have what you need. Now if your trailer has brakes, you need a controller wired-up to your truck.
everything should be ready to go unless you need a brake controller or power at the plug for a battery. and those are easy to take care of. if you are pulling something with the 4 or 5 pin just get the adapter and happy towing.
I have a aftermarket brake controller wired (installed by the dealer when I bought the truck) as well as the HD trailering package w/ mirrors, etc. I've towed a trailer with brakes and they work. My question is, is there POWER run to the plug at the back of the truck? i.e. Do the trailer batteries charge while I'm driving?
you dont have to do any wiring.. go to a parts store (wal-mart) and get the adapter.
I thought you had to connect the wire from the loom under the brake booster to the stud on the under hood fuse box, and add a fuse in the box? I could be wrong. I know the 09/10 tahoe's, yukon's, and suburban's always have that wire hanging out down to the frame rails
and the wire coiled up between your fuse box and fender is for the power under the dash to the brakecontrol. Just find 4 wires tied up under dash that are labeled and wire up your controller. Wire(trailer chargeline) on main harness down to frame will have wire coiled up onto and it goes to fuse box as well to the two posts on left end of fuse box if your standing at fender. back should have a plug and plug harness to plug a 7 way into. remove the dead lug from bumper and turn in the oem style 7 way.
OK, that's been done with the brake unit install I see. Both studs on the underhood fuse box have new wires connected to them and I have a fuse added. Cool, thanks.
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
