Chassis And Body Lube
Ok, I changed my oil the other day and I would like to perform the "chassis and body lube" as outlined in our manual. I did a search on the forum for a diagram or description on the points or # of points at least and came up dry (no pun intended). Anyone have this info or can point me to it if I am missing it?
Thanks in advance....
I may be wrong but I think there are only two grease points on GMT-900 1500's
And thats on the front end one on each side.
2wd are the only ones I've worked with.
(ball joints? tie rod?) I can't rememeber for sure what they're called but I know for a fact thats all thats on the 2007's and 2008's as I've worked on many at my jobsite and my own personal vehicle.
2500 and 3500 different story.
I guess you could put silicone lube on the weatherstripping and pull the driveshaft and lube the slip yoke too if you really wanna do a good job....
