Service 4wd
i have a 2004 silverado 2500hd. Today i let my girlfriend take my truck (first problem) then when she got home i got in the truck to move it and noticed the 4wd service light was on. there is no selector leds light up on the swith so you cant select anything.
Has anyone had a smillar problem. Hopefully an easy fix... :rolleyes:
well i think i anwsered my own question. I went out and tapped on the switch with alittle force, and turned the key on and the lights were now on. Hopefully the switchs contacts are just bad and a new switch will slove this problem.
You know, I recently had the exact same problem with my '04 HD. Couldn't select anything at all, but after awhile I guess it just "fixed" itself. Works fine now, but I suppose it was the switch.
Does this "Service 4WD" light just indicate trouble w/ the transfer case wiring rather than a service/maintenance reminder?
