E3 Spark Plug Hype
Alright guys, so pretty simple question today. What do y'all think of these E3 spark plugs? Are they worth the money? Or just a waste?
And what do you recommend as far as spark plugs go for these silverados?
never used em myself but I find it hard to believe the hype.
AC Delco, Champpion (the cheap 2$ plugs), NGK Iridium's are what I use.. the only advantage from the 2$ champions and the 20$ Iridium plugs is length of service, the AC Delco's are caught somewhere in between.
do NOT use Bosch, Ive done this and it was a mistake. truck never ran right the whole time they were in (which was about 2 weeks).. I may have simply had a defective plug, but it was enough for me not to go back.
i broke 2 bosch plugs in my last car, one broke while cruising down the hiway and luckily caused no damage, the other broke and took a chunk out of a valve with it. the first one the piece broke inside and the part that sparks to the tip was floating around. cant remember the technical term i just woke up. after that i stuck with ac delcos and never had a problem
If you do a search on here for E3 there are a few posts about them. From what I have read most have had a bad experience with them. I never used them. It seems from the general consensus is that most stick with AC or NGK and have great results.
I know Horsepower TV did a dyno run with them and stock plugs and showed a gain. But the dyno and real world is a little different IMO.
I guess you can try them and see how they do then report back. I don't need plugs for a long time so it will be a while for me to look into that area.
    btm
    btm
  • Who's Online   2 Members, 0 Anonymous, 1,422 Guests (See full list)
