Wiring Door Panels
I was wondering how hard would it be to swap out and wire up door panels that have auto windows and locks? My truck has neither and I really do want them lol. Does anyone have experience doing this?
It's not such a bad job IF you can find a donor truck in a boneyard. Swapping door panels, wiring harnesses window regulators and motors, and door locks is not a terribly hard deal but it takes some time. Wiring harness will plug into existing plugs in your truck and you 'll need to add relays (also scavenged from the donor truck).
So i need to find a donor truck and get the panels, relays, switches, motors, regulators, and wiring harness?
That would be the easiest. I think an excab. crewcab, Tahoe, Suburban would all work.
There are companies that offer aftermarket power window kits, but they aren't nearly as good as the OEM stuff. If you just wanted power locks and keyless entry that could be done with an alarm system and a pair of aftermarket actuators.
What about just swapping complete power doors over? I'm sure it would be easier, cost and availability might be the deal breakers though.
Id prefer to keep everything together. But it was an idea.
You could do that but the painting and redoing would get expensive... plus you can get the parts you need out of a damaged door for a ton less $$$ too.
They might be hard to find, but if you hit a few boneyards, I bet you can get everything you need. It would take a little determination.
Thats why Im wanting to stay oem. Do you think a wreck repair shop could do something like that?
Agreed, I wouldn't even consider it if they weren't already my color. As long as the truck has existing harnesses for power options and they don't have to be wired up it wouldn't be too hard I don't think. I do like the OP's idea better than complete door swaps though.
Oh I determined lol. Im determined to get the auto windows and doors and the new seats I want. It will just take ahile to find everything that matches and is in the colors I want. I do not want to have doors repainted to match the color of my truck. ugh lol
Matt,
I can help you with this also....I have been buying the Door Panel Kits with Windows/Lock Switches, Regulators and Wiring for a Few Years now and selling them....
Basically I unplug them from the truck at the Dash Area and get the complete door wiring....along with all the hardware needed, Lock Actuators, Etc.... I don't know if it ever takes any additional programming to get it to work, but I know all the parts you need.
If you are interested in this let me know...I will be making an additional parts run here in a couple weeks and could obtain these parts for you.
Thanks
Travis
    • WOW, something we agreed on. I only bought at sticker twice. A 94 impala ss and an Acura intagra type r. Made money on the first. Still have the second.
    • I prefer new, but not without a deal. Historically I've bought severely aged new inventory, leftover model year, unpopular configuration kind of stuff that sits around on dealer lots until they just want it gone. $10k off MSRP kind of stuff on a mid-priced truck. That really, really helps knock down that first year depreciation. It also requires being somewhat flexible on colors and options. I wouldn't buy a 4 cylinder if I was looking for an 8 cylinder, but if I got blue paint instead of black, or a great deal was lacking a minor option, I'm willing to overlook those things for savings.   Used <> used. Condition and history are everything. If I'm buying used I'm looking for cream of the crop. The truck from the guy who religiously pampers it, and then decides a year later he wants newer and nicer. NOT the ex-rental vehicle, or the crew cab traded in by the family with 7 kids who like to throw food, and the oil only got changed when there was time long after the oil life monitor started alerting.
    • @Grumpy Bear the conclusion from your post about doubling engine life has me curious. Are we literally talking an expected life of 250,000 miles potentially becomes 500,000 miles with a step up in filtration for fresh oil at "the oil factory" when it's bottled? I know you said that's a single variable among many, but, that's significant if the implication extends that far into a real world use case. I would think the oil marketing folks would really eat that up and make it known.   Particles introduced during oil change is a fairly easy one to avoid, but probably not intuitive as one would think. I.e. using a clean funnel. But...what was it wiped with? Paper towel leaves behind little fibers. A solvent if not dried is not something one would want to introduce into their engine with clean oil. And, keeping the oil filler neck clean and free of buildup.. Look at some guys engine bays and they're an absolute mess. Some say that's better than the drawbacks of cleaning it. I'm not a buyer of that idea.   I've also wondered if "flooding" the top end of the engine with oil while filling is a bad idea. During normal lubrication the oil flows in a gutter back into the galleys. But if you flood the area you're potentially washing the top of the rockers, springs, and other areas which may not get much oil wash normally, and you're mixing all that into the new oil. I just don't have the patience to pour slowly. 😆
    • It was a bad pump, i had a dealer next day the pump. Gm part #86591535. Tools needed 10mm socket, pliers for hose clamps, 1/2gal of Dexcool. About 30mins to remove and install, pump located near oil filter on driver's side frame rail. I had a local mobile mechanic delete the code, he had a snap on scan tool. My scanner could not delete the code. I drove back home about 700 miles since then, and no check engine light. Hope this helps someone in the future in the same situation i was in. Thank you to all that helped me.
