Howdy
Rebelphotog
Hey guys. New guy here from West Virginia. I drive a 2009 Silverado Z71+ ext. cab. I'm new to the site, but not to Chevy/GMC. In the past few years, I've had a 99 Sierra, 99 Silverado, 99 Jimmy 2 door, still currently own a 1999 Z28 as a weekend toy/moneypit, and the ol' lady drives a 05 Trailblazer..........we won't even get in to the GMs the rest of my family owns :cheers: So, needless to say, I'm a GM nut.
Right now, the truck has a 2.5" TGC leveling kit, Volant CAI, tinted windows (35% front, 20% rear--over factory tint), and Flowmaster 50 and is about to get new tires. I also plan to add rear blocks and a Zone 1.5" body lift in the very near future. I look forward to drooling over all of your trucks and learning a little bit along the way. :)
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
