Pics
I think I have the truck the way I want it so I am posting a pic to see what you all think
2010 silverado Z71
Borla exhaust
hypertech programmer
Pace Edwards bed cover
SS chrome wheels
Those wheels look great. I just missed buying a set of those for my truck at Fall Carlise. A guy I know got to them before me and stole them for $450.
Thats an awesome price. I got mine off ebay, wheels caps and new goodyear ls tires for $1200
Thanks for the kind words guys. Looking at all of your pics everyone of you has put a lot of time in your trucks. They all look awesome.
