5.3l Afm Poor Fuel Mileage?
Just curious if anyone has had this problem, i've got an 08 silverado with the 5.3L AFM engine and the last month or so it seems like its been using fuel at an abnormaly high rate. I travel mostly on the hwy and you can almost watch the gauge going down. I've got a k&n intake kit and dual exhaust but those are both over a year old so i'm trying to rule those things out. Any input would be great, before i go to the dealer.
I have afm on my truck its a brand new 2010 and it barely even comes on. I can have the cruise on on the highway and its still not on it sometimes will come on if I am going down a hill but often v8 will come back on even then. definately its in v4 alot less than I thought it would be
I would check and see if the gas station your using has changed from E10 to E15 recently and since its cold weather the winter gas will affect fuel economy.
Now i know they are not the same brand but my Volant intake was killing my MPGs until i got it tuned from blackbear. Justin said the injectors were just dumping fuel in it.
A few weeks ago in PIT i got a BB tune and had the AFM turned off and noticed an instant gain in MPGs and power.
Just food for thought. I never dealt with K&N before but maybe its causing the same problems. Id look into a BB tune also.
Dump some Lucas Fuel Injector Cleaner in your tank and see if it helps. I know it has on my truck and my Camaro. It seems like since they started putting 10% Ethanol in the gas the fuel injectors get dirty faster.
ethanol is a solvent, if anything its cleaning shit out
I have noticed also a drop in my fuel mileage going from an average of 19 down to low 16. Gas has an increased level of Ethanol (winter blend) right now. Price is up and mileage is down.
Gasoline is a solvent. Water is a solvent. Heck, any liquid is a "solvent' for some compound. (sorry, couldn't resist :fume: ) The trick is finding the right solvent for the issue at hand. It is my understanding that the better "injector cleaner" uses a Chevron-patented additive that dissolves "gummy organic deposits" on the intake side that standard solvents don't, and also that dissolve "oxide deposits from combustion" on the exit side. That's the idea, at least. If good quality gas is used, it shouldn't be needed.
IDK just something I read on the net, and also noticed in my vehicles. Guess it could just be the gas around my area.
Every supplier changes the fuel blend for colder conditions. My mileage has dropped off since they began doing this years ago.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
