Weight Loss 2
Continuing along the track to get some of the heft off the Escalade, today the trailer hitch came off.
That steel bar weighed in at 30.6 pounds
Next was a short section of exhaust tail pipe I removed to better tuck up the exhaust tip which was hanging down just a tad too low. That section weighed in right at 1/2 pound
So far the total weight loss is over 186 pounds!
Running Boards -45.6 -45.6
Stock exhaust manifolds
& Y-Pipe -55.0 -100.6
Headers & Y-Pipe +38.6 -62.1
Jack and base assembly -10 -72.1
Spare tire and wheel -71 -143.1
Spare tire hoist -7.8 -150.9
Exhaust shield (spare) -0.5 -151.4
Catalytic converters -4.0 -155.4
Short tail pipe section -0.5 -155.9
Tow Hitch and hardware -30.6 -186.5
Here's a pic of all the junk I have removed so far. The truck is no longer carrying that stuff, although headers replaced the exhaust manifolds and the air box has been replaced with a K&N unit
For speed of course. Cause escalades were made for that. :nopity:
Did you make the guess at the tow hitch being 30 lbs?
Good estimate, it weighed 30.6 lbs!
I've been looking over the truck to find ways to reduce more weight. I've come up with:
Reduce fuel to no more than half a tank
Reduce windshield fluid to 1/3
Drill lightening holes in both bumper steel cores
Same with the aluminum bracketery on the engine
Replace the standard drive shafts with aluminum units
Replace the transmission mount with a home-made aluminium unit
Cut off excess of all suspension mounts
and so forth...
If a guy really wanted to get serious there is one big, well, huge weight reduction, but that would change the nature of the vehicle.
That would be to remove the transfer case, driveshaft, front differential, both axle shafts and all hardware and mounts. That would be every bit of 500 or more pounds. But now the thing would no longer be AWD. That means the rear tires would never again be able to hook up. I can already spin two rear and one front! That would make the truck very fast without any engine stuff, but, like I said, would change it's nature.
I am kicking that around but it seems to be a better idea to just keep all that stuff and make a butt more more torque from a cam and a supercharger and get around 700BHP pushing all that weight around.
I don't have a good baseline on the weight, so next is to get a good weight on the vehicle and look it again.
More to come...
and so forth...
More to come...
I definitely wouldn't be cutting on the suspension and such just because I could. Doesn't seem like it would be good for the integrity of the truck. Unless your trying to race or something. But I don't know your intentions I guess. I would add some power adders and beef the powertrain up if it was me. But like I said, I don't know what you are shooting for.
and so forth...
More to come...
wow, you need help :thumbs:
