What Are You Towing?
Josh
  • Replies 138
Nice set-up! :thumbs:
What kind of trailer is that? What is the lenght/weight?
E :lol:
2011 Keystone Passport 2850 RL 30 ft. 5100 lbs empty
2009 Crossroads Sunset Trail ST30BH. ~6900 lbs fully loaded, CAT scale weights. (Guessing ~5600 lbs dry, but the manufacturer number was ~5200 lbs dry).
Earlier today going to my gf's parents house to pickup a matress,box,frame.
Why not just put it in your bed? :smash:
I had to drive over a hundred miles each way to pick it up and cold Canadian weather plus slush and salt so I didn't want to risk getting it dirty or damaged. If it was summer I would of fit it in the bed
Btw it was minus 20 degrees Celsius here last night lol
Makes sense now. :smash:
^^^ He's not kidding!! Thankful for my remote start this morning I'll tell you!!
Finally had a chance to hook up my Airstream for a test tow behind my 2011 GMC Denali 2500HD 4X4. I think I could easily tow twice this weight. This beast pulls as expected.
Nice combo. What year/model Airstream?
My Dad left me his bass boat in his will. He was killed in a motorcycle accident Oct 09.
We also have a Fleetwood Yuma pop-up camper, but have no pics at work to post up.
Figured I post the last pic of my Pops since he left me his boat. He was very happy in this picture as we had lost my mom to cancer the year before.
A bit of a crappy BlackBerry picture but none the less it's one of my trailers. Don't have one with my snowmobiles just yet.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
